KamiQuazi Posted August 16, 2005 Posted August 16, 2005 Here is my pcs new specs! CPU AMD 64 |3500+ ATHLON 64 939 RT - RetailI OCZ 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail MSI K8N Neo4 Platinum nVidia Socket 939 Motherboard / Audio / PCI Express / USB 2.0 & Firewire / Serial ATA Thermaltake VENUS 12 80mm Ball Cooling Fan/Heatsink - Retail Ultra / X-Connect / 500-Watt / ATX / Dual 80mm Fan / Titanium-Black / Modular Power Supply Thanks all 4 ur help!!!
cumminbk Posted August 16, 2005 Posted August 16, 2005 Congrats! How much did this cost you and what video card are you going to be using with your system?
ripken204 Posted August 16, 2005 Posted August 16, 2005 (edited) well this is what we originally made up but apparently he changed a few thingshttp://frontiernet.net/~unholyknights/cyberpunkuscomp.htmwhy didnt u get the heatsink i suggested? much better Edited August 16, 2005 by ripken204
glent Posted August 16, 2005 Posted August 16, 2005 Looking nice!, You should have bought the thermalright, The thermaltakes are noisey as hell
KamiQuazi Posted August 16, 2005 Author Posted August 16, 2005 @Ripken: I didnt it would have fit in my case... the fan is 92mm and my cpu fan right now is really close to my case fans already...lol... my AMD Althlon xp board is a MSI MS-5378...
JuMz Posted August 16, 2005 Posted August 16, 2005 Here is my pcs new specs! CPU AMD 64 |3500+ ATHLON 64 939 RT - RetailI OCZ 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail MSI K8N Neo4 Platinum nVidia Socket 939 Motherboard / Audio / PCI Express / USB 2.0 & Firewire / Serial ATA Thermaltake VENUS 12 80mm Ball Cooling Fan/Heatsink - Retail Ultra / X-Connect / 500-Watt / ATX / Dual 80mm Fan / Titanium-Black / Modular Power Supply Thanks all 4 ur help!!! <{POST_SNAPBACK}>Just out of curiousity, is there a particular reason you chose the Neo4 Vs. the DFI NF4 Ultra or SLI versions?
KamiQuazi Posted August 16, 2005 Author Posted August 16, 2005 Don´T like SLI... i thick it is pointless just as a dual-cpu mobos are
Porn Loader Posted August 16, 2005 Posted August 16, 2005 (edited) nevermind, post deleted Edited August 16, 2005 by Porn Loader
