need switchs and way to register for the following (unless it doesnt require registering like the one below)
RED=NEED SWITCH & REGISTER METHOD!
NO COLOR=JUST SWITCH!
ECHO.
ECHO Installing Steam for Counter-Strike
ECHO Please wait...
start /wait %systemdrive\install\Applications\Steam\SteamInstall.exe
ECHO.
ECHO Installing #1 DVD Ripper
ECHO Please wait...
start /wait %systemdrive%\install\Applications\Dvdripper\no1dvdrip.exe
ECHO.
ECHO Installing Kazaa Lite Codec Pack
ECHO Please Wait...
start /wait %systemdrive%\install\Applications\kazaacodec\kazaacodec.exe
ECHO.
ECHO Installing Azureus Java Bit Torrent Client
ECHO Please wait...
start /wait %systemdrive%\install\Applications\Azureus\Azureus.exe
ECHO.
ECHO Installing NOD 32 Anti-Virus
ECHO Please wait...
start /wait %systemdrive%\install\Applications\NOD32\Setup.exe
ECHO.
ECHO Installing AIM 5.2
ECHO Please wait...
start /wait %systemdrive%\install\Applications\AIM\Install_AIM.exe
ECHO.
ECHO Installing Diskeeper 8.0
ECHO Please wait...
start /wait %systemdrive%\install\Applications\diskeeper\Setup.exe
probably more to come later, but thats a start. Thanks!
hi,
look @ the application switches stickies , 80% of these are there
nod32 is /silentmode
azureus is /S i think
but look in the afforementioned thread & u will find your answer
We cant help those who dont take the time 2 help themselves :)
good luck
You are one lazy son of a dog. I mean, we all miss a thread sometimes on the search, but you are just wanting us to do the work for you. Use the search button!
]Bonkers[
hi,
also you could search for "Universal Silent Switch Finder" here on the forums, it looks which installer a setup-executabe uses...
hope this helps a bit
cya
Killer Bee
]Bonkers[
i think the same as you, i've read all the time how people ask something like if the search button don't exists, but you lose all the points when you say "lazy son of a dog" this forum it's not based on insults and specially if he is a newbie here and probably he haven't read the forum rules that i recommend both to read.
Indeed...rules...yes.....
just because I'm bored....
AIM is /S or /silent, not sure which
K-Lite is /VerySilent
Steam, i don't think there is one. You'll have to ask Valve. But they're prety cool about that stuff.
Also, you'll get better quality on your DVD Backups if you used the stuff from www.doom9.org
]Bonkers[
It's good of you, SiMoNsAyS.
If we can't guide or help people, we don't have to hurt their feelings in any way.
You're completely right. Newbies to this site must be guided in a polite way.
then I suggest you refer "newbies" as "new people" as "newbies" could be deemed hurtful to some. We must be politically correct.... :)
You're right.
Not every newbie to this site is newbie to computer field. I didn't mean "naive", however. :rolleyes:
YES! My appologies to: battleangel3222.
Steam:
steam.exe /silent
taskkill /f /im steam.exe
Kazaa Codec Pack:
start /wait %systemdrive%\install\Applications\Kazaa\klcodec225f.exe /silent
Azureus:
start /wait %systemdrive%\install\Applications\Azureus\Azureus.exe /S
NOD32:
start /wait %systemdrive%\install\Applications\NOD32\Setup.exe /silentmode
AIM:
start /wait %systemdrive%\install\Applications\AIM\Install_AIM.exe /s
Diskeeper:
/s /v"/qn REBOOT=Suppress
You said you searched? I don't think you searched very hard. I found all of those for you in about 10 minutes... Yes, using the search feature!
