I just built a new computer and I seemed to have made the mistake of buying two vantec tornado 80mm fans. With the fans being so loud, no one in the house can sleep. My question is, can anyone recommend the most quiet 80mm fans anywhere? Currently I'm running open case but I'm so afraid something will ever fall on my CPU fan that I'm frantic for a solution. I need quiet so that I can sleep, but I also need to stay cool! Thanks for the help.
Tornados are horrible for their noise. Even undervolting them won't help much... :no:
If you want quiet fans, Nexus or Scythe are the way to go. SilentPCReview.com is a great place to look for quiet computing tips. :)
