[Help] Problem with Local users and groups
In Computer Management I have a problem with Local users and groups.
When I click on Local users and groups it sais "Unable to access the computer..."
See the picture.
What could be the problem?
Title edited -- Please, use [TAGS] in your topic's title.
--Sonic
Hello
Is your pc under a domain ?
Have you modify local strategy ?
Have you update the microsoft management console ?
Try to verify the files are on your pc or not ?
Search *.msc files on windows\system32 and found usermgmt.msc
Try to reinstall it
Version 3.0
http://www.microsoft.com/downloads/details...a2-cf20902ffae0
Version 1.2
http://www.microsoft.com/downloads/details...&DisplayLang=en
or restore the files from xp cd
www.faqxp.com or www.microsoft.com/technet
Edited by KRYOGENIUS
Thanks for your reply.
The PC is not under a domain, didn't modify local strategy, no updates (XP with integrated SP2), there is lusrmgr.msc and not usermgmt.msc.
Is your CD is nLited ?
I assume you have XP Pro because "Local users and groups" isn't available on Home Edition.
