coucou Posted June 30, 2005 Posted June 30, 2005 Hi,I nearly finished my UA (WinXP+over 100 Appz) DVD and there's 2 problems remains. 1 error and 1 cosmetic.1) No disk error: after the WinXP install and restart, i got an error message: "'Windows No Disk' 'There is no disk in the drive. Cancel] [Try Again] [Continue]" . I clicked 2 or 3 times on [Continue] and... WPI started from the DVD.Anyone have any idea how to solve this problem???2) Cosmetic: how to make the RunOnceEx dialog wider that i might try is making a longer text string (see enclosed image)???Regardscoucou
almulder Posted July 1, 2005 Posted July 1, 2005 upload your "WPI.cmd" file and I am sure myself and other can look at the start up code to see if there is a problem with it, and we can go from there.As far as the Runonec.exe i am not sure.
blinkdt Posted July 1, 2005 Posted July 1, 2005 On the "cosmetic" issue, it's been asked in this forum and others with no solution forthcoming. The only "fix" is to keep the entries short with some creative editing. And remember that they will expand when bolded during the install, making things even worse.
coucou Posted July 1, 2005 Author Posted July 1, 2005 @almulder: here enclosed my wpi.md fileAs you can notice to look for DVD, i'm using "win51" file. The same in generate.js file.Here the winnt.sif command [GuiRunOnce]%systemdrive%\install\wpi\wpi.cmd@linkdt: Tnx for enlightening. I do not spent more time searching.Regardscoucou
