Happy-Dude Posted April 27, 2008 Share Posted April 27, 2008 Heya guys!!So, I am not understanding silent switches at all.From what I understand, silent switches are the same thing as like customizing an install by checking the boxes and stuff, right? (so the check boxes would be called switches?)Even looking at this: http://www.msfn.org/board/Looking-for-a-ne...-8-t116212.html , I had not clue what they were talking about (which is probably due to me having no experience with the AVG installer).So, can someone clarify this to me? Also, it would help if you can provide me with an example, such as using the CCleaner (standard build : http://www.ccleaner.com/download/builds) or Advanced WindowsCare Personal (http://www.iobit.com/advancedwindowscareper.html) --> both of which have toolbars in them.I would like to be able to install the programs into nLite (or using WPI or XPlode) without the toolbars. I don't have a clue to do that. Also, how do I make these "customizations" into nLite (like into a single .cab file), or even put them into WPI so it does it for me?Thanks for your responses in advanced !! Link to comment Share on other sites More sharing options...
anonymous_user Posted April 27, 2008 Share Posted April 27, 2008 (edited) Look at this thread to learn howto make addons.Also if you want CCleaner without the toolbar, make sure to use the slim build found here.Also look in this thread for a brief tutorial on using WPI. Edited April 27, 2008 by anonymous_user Link to comment Share on other sites More sharing options...
Happy-Dude Posted April 27, 2008 Author Share Posted April 27, 2008 Thanks for the response. I will definitely take a look at the tutorials and try to understand them.Can anyone post an example on creating a Advanced WindowsCare Personal add-on so I can take a look on how everything is supposed to be? Thanks.Here are the steps required to create the add-on:1: Create a new folder and name it after your application, ie uTorrent1.32: Within the above folder, create another folder called SVCPACK3: Place your switchless installer within the SVCPACK folder4: Rename the ini file to match the name of you add-on, for example ENTRIES_UTORRENT.ini5: Open the ini file and edit the appropriate details under the [general] section as required, eg:[general]builddate=2005/14/1description=uTorrentlanguage=Englishtitle=uTorrent is an efficient and feature rich BitTorrent client for Windows sporting a very small footprintversion=1.3website=http://utorrent.com/6: Navigate to the [AddProgram] section of the ini file and change the name to the exe file that is within the SVCPACK folder, eg utorrent.exe (keep it as simple as possible)Your ENTRIES_PROGRAM.ini file will look something like this:[general]builddate=11/21/2005description=product description herelanguage=Englishtitle=Program Nameversion=1.0website=http://www.programwebsite.com/[EditFile]I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram[AddProgram]PROGRAM.EXEYou should now have a setup that looks something like this:within the SVCPACK folder is ur PROGRAM.EXE switchless installer.7: Ok, the next step is to create the .cab file. Using MakeCab or CabPack, a freeware utility available here (or any method you wish!) create the cab file of the SVCPACK folder and ENTRIES_PROGRAM.ini file. Rename this cab file to something appropriate eg uTorrent_1.3.cab.THE NEXT STEP IS THE MOST IMPORTANT!Before sharing your new add-on, please TEST IT! It is imperitive you test your add-on before posting to avoid problems.--Question:3: Place your switchless installer within the SVCPACK folder4: Rename the ini file to match the name of you add-on, for example ENTRIES_UTORRENT.ini5: Open the ini file and edit the appropriate details under the [general] section as required, eg:-----> Where'd we get the .ini file from originally? Do we need to create one (if so, how)?Also, the tutorial with WPI makes and example of CCleaner, but doesn't (or at least I don't think it does) include a switch to uncheck the toolbar.Can someone please provide me with an example using Advanced WindowsCare Personal (has a toolbar that needs to be unchecked, so I would know how to adapt for other installers)? Link to comment Share on other sites More sharing options...
mara- Posted April 27, 2008 Share Posted April 27, 2008 -----> Where'd we get the .ini file from originally? Do we need to create one (if so, how)?Open Notepad, choose Save As, under "Save as type" choose "All Files", under "Encoding" choose "Unicode". Now for the "File Name" enter name you want with extension .ini. For example ENTRIES_UTORRENT.ini.Cheers Link to comment Share on other sites More sharing options...
anonymous_user Posted April 28, 2008 Share Posted April 28, 2008 I dont think CCleaner has a switch for the toolbar. Like I said, use the slim installer.If Advanced WindowsCare Personal installs a toolbar, you may need an AutoIT script that unchecks the toolbar option. Ask in the Application Installs forum. Link to comment Share on other sites More sharing options...
