can you open the .cab file
if you can .. try extracting the files from it and try to than add the ENTIES_XXX.ini file
see if its goes that way
IF you cant open the cab than redownload it and see if thats works
PS
use the MD5 to make sure the file is 100 % ok :)
PS next time add the thumbnail image ;)
Edited by ZcWorld
and why do u use a remove component addon with nlite ??? nlite can do that for u.......there is no need for that addons.......
