ARG! This is so frustrating!
At first with just the %UserProfile% the game would save into the All Users Sharded Documents, so I added the %AllUsersProfile% to change that, but now it just saves on the root of that drive (F:\; a folder named 'EA Games' is created, just as if it were saved in the original My Documents) instead of inside the "mydoc" folder... The game is The Sims 2.
Run.bat:
SET USERPROFILE=f:\mydoc
SET ALLUSERSPROFILE=f:\mydoc
Sims2SP1.exe
Edited by arablizzard2413
SET *=<dir> only works in a batch file, for the duration of that batch file.
REG ADD "HKLM\System\CurrentControlSet\Control\Session Manager\Enviroment" /v "UserProfile" /d "F:\MyDoc"
REG ADD "HKLM\System\CurrentControlSet\Control\Session Manager\Enviroment" /v "AllUsersProfile" /d "F:\MyDoc"
Tis is more permanent. ;)
I doubt that works ... UserProfile & AllUsersProfile don't set by default in your regkey path ...
Stupid suggestion : do not try to fool the game. Instead, move its files elsewhere after playing it, and move its files back before playing it.
Run.bat :
@ECHO OFF
MOVE /Y "F:\Where you want the files to be\*.*" "C:\Where the game save its files by default\*.*"
START /WAIT "C:\Where the game is\Sims2SP1.exe"
MOVE /Y "C:\Where the game save its files by default\*.*" "F:\Where you want the files to be\*.*"
It will be fully transparent both for you and for the game.
Note: the MOVE command can move only files, not folders. If there is folders, you need to use XCOPY + DEL + RD
I get what you mean, you only want Sims to install to that path for it's savegames but you don't want that to be your permanent My Documents.
First, EA uses %UserProfile%\My Doucmnets and secondly, it always checks %UserProfile%\My Documents instead of where the savegame was actually installed to. The batch only uses set*=* in the batch itself, not any programs launched by it.
Try Delprat's method.
Edited by T D
Environments are passed between parent and child processes, so if you open a command prompt and launch a process it will inherit the environment.
What you could do is use FileMon to see what paths are being probed by the game - maybe it's not only checking the path but ownership also, or something like that.
Perhaps it is indeed looking for "%UserProfile%\My Documents", and you don't have a "My Documents" folder under "f:\mydoc"?
