roy1984 Posted September 12, 2004 Posted September 12, 2004 i already installed sound card and sound driver in my windows 98 se, but no sound output, in "dxdiag" , "sound" it display no sound card was found , but i try use the Cd-rom to play the CD with the "play" button on the ROM it got sound , other then that all the software and windows dun have any sound, my hardware driver i check all, all is in enable status, included "sound" in "control panel" i set into windows default also dun have sound , it this the bug of windows 98 se ? it always recover back all configuration so that i can't do anything on it, help me plz
jaclaz Posted September 12, 2004 Posted September 12, 2004 Which card?Which driver?There are four possibilities, if you right click my computer and select Hardware:a) Soundcard has a question markb) Soundcard has no question mark, but doubleclicking on it it says device not working or something similarc) Soundcard has a red crossd) Sondcard is not shownRemedies:a) Remove card from hardware list, reboot, let plug 'n play re-detect itb) Remove card from hardware list, reboot, let plug 'n play re-detect itc) Enable it, if not working goto a) or B)d) Switch off pc, physically remove card, place it in the slot, switch on pc, let plug 'n play detect itIf after doing the above still not works, probably it is an IRQ conflict, you will need to post your IRQ settings.jaclaz
Stanislavs Posted September 24, 2004 Posted September 24, 2004 hehe! I once had that with graphics card and i couldnt see anything on monitor. At the end we called a computer repairmen and he charged us about 50€ for connecting the card correctly
