Guest Posted March 11, 2024 Posted March 11, 2024 i recently purchased a new computer An HP Elite 8300 SFF From 2012 thats been working well the only issue with it is recently.the computer just completely stopped working with the psu fan running at max speed always and a constently flashing 4 red light beep code ive done researching into.the problems and still have not found a way to fix it would anyone here have advice on what this could be? thanks
jaclaz Posted March 11, 2024 Posted March 11, 2024 https://h30434.www3.hp.com/t5/Desktop-Hardware-and-Upgrade-Questions/4-TIMES-BEEP-RED-LIGHT/td-p/7451727 Power supply or graphic card?
Guest Posted March 11, 2024 Posted March 11, 2024 (edited) 7 hours ago, jaclaz said: https://h30434.www3.hp.com/t5/Desktop-Hardware-and-Upgrade-Questions/4-TIMES-BEEP-RED-LIGHT/td-p/7451727 Power supply or graphic card? that could be it but it would take bigger research to know for sure that's the cause as these computer seem to be very confusing when it comes to computer issues Edited March 11, 2024 by legacyfan
erpdude8 Posted June 5, 2024 Posted June 5, 2024 (edited) well the only way to "fix" your problem is with "trial and error" methods such as either replacing the whole PSU as mentioned in the following threads: https://h30434.www3.hp.com/t5/Desktop-Hardware-and-Upgrade-Questions/Hp-Compaq-Elite-8300-SFF-psu-graphics-upgrade/td-p/5743592 https://h30434.www3.hp.com/t5/Desktop-Hardware-and-Upgrade-Questions/Power-Supply-Upgrade-for-a-HP-Compaq-Elite-8300-CMT/td-p/6928080 a youtube video link on how to replace the psu on the hp elite 8300 or replacing the entire motherboard https://forums.anandtech.com/threads/hp-compaq-elite-8300-small-form-factor-installing-new-board-processor.2580369/ and test again with the replacement components. sometimes, there's no easy way to tell but to use such trial-and-error methods Edited June 5, 2024 by erpdude8
Guest Posted September 10, 2024 Posted September 10, 2024 Update : Sep 10 2024: after a year i finally have a sturdy dell optiplex 9020 sff desktop without legacy windows support and so for it runs as smooth as butter and has not given me any issues
