west117wolf Posted April 10, 2011 Share Posted April 10, 2011 When I plug in the color coded (Pink and Black) connections into the 3.5 jack, no sound comes through the headset. When on teamspeak other members cannot hear me either. Can anyone help me with this problem. Thanks.WestThe headset worked well on my previous version of Windows which was xp. Link to comment Share on other sites More sharing options...
Tripredacus Posted April 10, 2011 Share Posted April 10, 2011 Windows 7 sound manager (by itself) is a little different, and less PnP than previous versions. But we don't know what sound manager you are using. For example, if you are using a Realtek sound chip, you should have that software installed. What is your sound controller? Link to comment Share on other sites More sharing options...
west117wolf Posted April 10, 2011 Author Share Posted April 10, 2011 Thanks for the reply. My sound controller is : SoundBlaster X-Fi Extreme Audio. I will look forward to hearing from you.WestDxDiag.txt Link to comment Share on other sites More sharing options...
