HFSLIP Need Help Using-Need How to Manual!
There is something called hfcleanup to reduce the sourcess during hfslip execution. But please be advised that it is not supported anymore due to lack of interest. Details are on the hfslip website.
I may also suggest visiting unattended.msfn.org for details on how to set up keys and how to set up a winnt.sif file. There are two automated ways to set up this file, one is a deployment tool that resides on your xp installation cd and you can always run nlite to get it. In either case, you can simpliy copy the winnt.sif file to either your source\i386 folder or your fix folder prior to running hfslip.
I hope you don't mind my adding to this thread. It seems to be a good one! I would like to know some links to tutorials or guides on how to remove some components using HFSLIP? For example how to remove Remote Registry from even installing, or Windows Tour.
Well, this one's easy.
Put this in an INF file, like AXANT5 or one of the HIV files...
HKLM,"SYSTEM\CurrentControlSet\Services\RemoteRegistry","Start",0x10001,04,00,00,00
It sets RemoteRegistry Service to disabled. Warning, you won't be able to use any fancy remote admin tools on any of your users' PCs though.
Windows Tour, you just have to know the filename and comment it out from TXTSETUP. You might benefit from running nLite but then comparing pre- and post-Windows files to see what nLite is actually deleting.
That is a good idea to compare the differences. I really want to be able to use the options nLite provided without actually running SOURCESS through it (because it doesn't work too well!). It is only for a handful of computers which won't be changing much after initial setup so I don't need all the remote tools. But if I can leave it in and set it to disabled to start with, that will do fine for some extra security. Thanks for the tips :)
My log file.
HFSLIP Version - 1.7.0 build 71114
HFSLIP Path - C:\HFSLIP\
OS in SOURCESS - 2000 SP4 English
MSIE Version - 2KIE6
DirectX Slipstreamed
Drivers - DRIVER.CAB Updated
CD Install Path - Default
CDTAG - CDROM_NT.5
Files in your FIX folder:
Files in your HF folder:
aolsupp.exe
directx_nov2007_redist.exe
gdiplus_dnld.exe
IE6.0sp1-KB834707-Windows-2000-XP-x86-ENU.exe
IE6.0sp1-KB905495-Windows2000-x86-ENU.exe
Initiator-2.05-build3392-x86fre.exe
KB832414_MSXML2.5_x86.exe
MDAC_TYP.EXE
MDAC253-KB911562-x86-ENU.exe
MDAC253-KB927779-x86-ENU.exe
MDAC271-KB911562-x86-ENU.exe
MDAC271-KB927779-x86-ENU.exe
MDAC281-KB911562-x86-ENU.exe
MDAC281-KB927779-x86-ENU.exe
MDAC28-KB911562-x86-ENU.exe
MDAC28-KB927779-x86-ENU.exe
MPSetup.exe
msxml2sp6-kb887606-x86-enu.exe
msxml4-KB941833-enu.exe
msxml6-KB933579-enu-amd64.exe
msxml6-KB933579-enu-x86.exe
OE5.5sp2-KB911567-Windows2000sp4-x86-ENU.exe
OE5.5sp2-KB923694-Windows2000-x86-ENU.exe
OE5.5sp2-KB941202-Windows2000-x86-ENU.exe
oe6.0sp1-KB897715-Windows-2000-XP-x86-ENU.exe
OE6.0sp1-KB911567-Windows-2000-XP-x86-ENU.exe
OE6.0sp1-KB923694-Windows2000-x86-ENU.exe
OE6.0sp1-KB941202-Windows2000-x86-ENU.exe
Q820608_W2K_SP5_X86_EN.exe
rootsupd_fe44934fd80dd11fec2f0f9b24431658a4f6d589.exe
StepByStepInteractiveTraining-KB923723-x86-ENU.exe
W2KSP4_EN.EXE
Windows2000-KB821887-x86-ENU.exe
Windows2000-KB839228-x86-ENU.EXE
Windows2000-KB842773-x86-ENU.EXE
Windows2000-KB885912-x86-ENU.EXE
Windows2000-KB890046-x86-ENU.EXE
Windows2000-KB890859-x86-ENU.EXE
Windows2000-KB891861-v2-x86-ENU.EXE
Windows2000-KB892944-x86-ENU.EXE
Windows2000-KB893066-v2-x86-ENU.EXE
Windows2000-KB893086-x86-ENU.EXE
Windows2000-KB893756-x86-ENU.EXE
Windows2000-KB894320-x86-ENU.EXE
Windows2000-KB894391-x86-ENU.EXE
Windows2000-KB894395-x86-ENU.EXE
Windows2000-KB896358-x86-ENU.EXE
Windows2000-KB896422-x86-ENU.EXE
Windows2000-KB896423-x86-ENU.EXE
Windows2000-KB896424-x86-ENU.EXE
Windows2000-KB899587-x86-ENU.EXE
Windows2000-KB899588-x86-ENU.EXE
Windows2000-KB899589-x86-ENU.EXE
Windows2000-KB899591-x86-ENU.EXE
Windows2000-KB900725-x86-ENU.EXE
Windows2000-KB901017-x86-ENU.EXE
Windows2000-KB901214-x86-ENU.EXE
Windows2000-KB902400-x86-ENU.EXE
Windows2000-KB904368-v3-x86-ENU.EXE
Windows2000-KB904706-v2-x86-ENU.exe
Windows2000-KB905414-x86-ENU.EXE
Windows2000-KB905749-x86-ENU.EXE
Windows2000-KB908506-x86-ENU.EXE
Windows2000-KB908519-x86-ENU.EXE
Windows2000-KB908523-x86-ENU.EXE
Windows2000-KB908531-v2-x86-ENU.EXE
Windows2000-KB911280-v2-x86-ENU.EXE
Windows2000-KB912919-x86-ENU.EXE
Windows2000-KB913580-x86-ENU.EXE
Windows2000-KB914388-x86-ENU.EXE
Windows2000-KB914389-x86-ENU.EXE
Windows2000-KB917008-x86-ENU.EXE
Windows2000-KB917159-x86-ENU.EXE
Windows2000-KB917344-x86-ENU.EXE
Windows2000-KB917422-x86-ENU.EXE
Windows2000-KB917537-x86-ENU.EXE
Windows2000-KB917736-x86-ENU.EXE
Windows2000-KB917953-x86-ENU.EXE
Windows2000-KB918118-x86-ENU.EXE
Windows2000-KB920213-x86-ENU.EXE
Windows2000-KB920670-x86-ENU.EXE
Windows2000-KB920683-x86-ENU.EXE
Windows2000-KB920685-x86-ENU.EXE
Windows2000-KB920958-v2-x86-ENU.EXE
Windows2000-KB921398-x86-ENU.EXE
Windows2000-KB921503-x86-ENU.EXE
Windows2000-KB921883-x86-ENU.EXE
Windows2000-KB922582-x86-ENU.EXE
Windows2000-KB922616-x86-ENU.EXE
Windows2000-KB923191-x86-ENU.EXE
Windows2000-KB923414-x86-ENU.EXE
Windows2000-KB923689-x86-ENU.EXE
Windows2000-KB923810-x86-ENU.EXE
Windows2000-KB923980-x86-ENU.EXE
Windows2000-KB924191-v2-x86-ENU.EXE
Windows2000-KB924270-x86-ENU.EXE
Windows2000-KB924432-x86-ENU.EXE
Windows2000-KB924667-x86-ENU.EXE
Windows2000-KB924867-x86-ENU.EXE
Windows2000-KB925308-x86-ENU.EXE
Windows2000-KB925902-x86-ENU.EXE
Windows2000-KB926121-x86-ENU.EXE
Windows2000-KB926122-x86-ENU.EXE
Windows2000-KB926247-x86-ENU.EXE
Windows2000-KB926436-x86-ENU.EXE
Windows2000-KB927891-x86-ENU.EXE
Windows2000-KB928843-x86-ENU.EXE
Windows2000-KB930178-x86-ENU.EXE
Windows2000-KB931784-x86-ENU.EXE
Windows2000-KB932168-x86-ENU.EXE
Windows2000-KB933729-x86-ENU.EXE
Windows2000-KB935839-x86-ENU.EXE
Windows2000-KB935840-x86-ENU.EXE
Windows2000-KB935843-x86-ENU.EXE
Windows2000-KB935966-x86-ENU.EXE
Windows2000-KB936021-x86-ENU.EXE
Windows2000-KB938827-x86-ENU.EXE
Windows2000-KB938829-x86-ENU.EXE
Windows2000-KB941672-x86-ENU.EXE
WindowsInstaller-KB893803-v2-x86.exe
Windows-KB890830-V1.35.exe
Windows-KB909520-v1.000-x86-ENU.exe
WindowsMedia6-KB925398-v2-x86-ENU.exe
WindowsMedia7-KB917734-x86-ENU.exe
WindowsMedia7-KB936782-x86-ENU.exe
WindowsMedia9-KB891122-x86-Global-ENU.exe
WindowsMedia9-KB917734-x86-ENU.exe
WindowsMedia-KB911564-x86-ENU.exe
WindowsRightsManagementServicesSP2-KB917275-Client-ENU-x86.exe
WindowsUpdateAgent30-x86.exe
wmfdist.exe
msxml2.msi
Files in your HFCABS folder:
_IE6_HFSLIP.CAB
_IE6b_HFSLIP.CAB
_OE6_HFSLIP.CAB
BRANDING.CAB
IEAWSDC.CAB
IEW2K_1.CAB
IEW2K_2.CAB
IEW2K_3.CAB
IEW2K_4.CAB
LegitCheckControl.cab
MAILNEWS.CAB
MuCatalogWebControl.cab
MUWEB_SITE.CAB
OEEXCEP.CAB
OGAControl.cab
OPUC4.CAB
SCRIPTEN.CAB
WAB.CAB
Files in your HFSVCPACK folder:
Files in your HFSVCPACK_SW1 folder:
Files in your HFSVCPACK_SW2 folder:
Files in your HFGUIRUNONCE folder:
UPHClean-Setup.msi
Files in your HFTOOLS folder:
7za.exe
HFSLIP_POST_getnewfiles_v3.cmd
modifyPE.exe
reg.exe
HFSLIP run time: 18m13s
Edited by new2hfslip
new2 - you really have to visit tomcat76's hotfix list site to get the essential hotfixes. You have a mixed bag of ie5 and ie6 updates as well as oe5 and oe6 updates. You need one or the other. Once you visit TC's site, select what you want to slipstream on top and grab all the files on the bottom. Your HF folder should not have files that aren't listed.
I will look again and take out the files that are not needed.
The ISO that was made is working good and the OS no problems. (So far anyway.) :sneaky:
If the OS is running fine you must be very lucky. It's been a while since I've seen such a mess.
> MDAC281-KB927779-x86-ENU.exe <--- use this one only
If you're slipstreaming MDAC 2.8 SP1 (I hope the MDAC_TYP.EXE file is MDAC 2.8 SP1 and not an earlier version because they have the same file name), you only need the hotfixes for MDAC 2.8 SP1. KB927779 replaces KB911562 so you only need KB927779.
> OE6.0sp1-KB941202-Windows2000-x86-ENU.exe <--- use this one only
When slipstreaming IE6, you are also slipstreaming OE6. Do not include hotfixes for OE 5.5 SP2. KB941202 is the latest cumulative update so there's no need for the other OE6 SP1 updates.
I didn't know you have a 64-bit version of Windows 2000. I suggest you remove this. :)
Not supported to my knowledge.
Not supported. HFSLIP doesn't support slipstreaming of WMP 7.1 so these hotfixes are useless. I'm not surprised Windows Update asked you to install the KB936782 hotfix for WMP9.
Thank you again. I'll edit the hot fix files as you specified. LOL I guess I am lucky it works. Perhaps HFSLIP just ignored the ones that were not supposed to be there or I just got lucky. :whistle:
Well I got a new ISO made and it works without problems. I took only the files that were listed on Tommy's website and put them in the mix. I wonder about all the optional patches and hot fixes on the Windows Download website. Some of them seem to, per the description, that they expand the functionality of Windows 2000 in small limited ways in a particular area. That is how I needed up with so many originally. One hot fix in particular is the Security update Service Pack one that contains all the security updates to a certain point. It was released a long while after Service Pack 4. I wonder why those are not recommended by the slipstream pros to be used. Thank you for your help. :thumbup
Oh two points of interest while HFSLIP was opening the hot fixes. During the phase I am refering to HFSLIP opens the hot fixes and copies the files. Two Hot fixes when HFSLIP opened them had zero files copied. I thought that rather odd. They were: KB904368 and KB926121. Anyone know if that has any significance?
Are you talking about the update rollup? It's on our update lists. Search for KB891861-v2.
KB904368 is replaced by KB891861-v2 (so do you have the update rollup or not?) and KB926121 doesn't update any files.
