September 10, 200718 yr I just need to know how to make this default instead of the standard notepad ??Thanks
September 11, 200718 yr 1. Make a text file. (by right clicking in a blank area, selecting 'New', than click on 'text document'.2. right click on the text file, click properties. When the new window appears. type in 'c' for change -- next to the 'Open's with' bar3. Select 'notepad2' if its under the 'recommend programs' tab. If its not there, click the browse command button and find the .exe file for notepad2.3a) Click the button for 'Always use the selected program to open this kind of file'.3b) Click ok. Now your done.You can do this for all types of files.There are some addons that can replace the normal notepad with notepad2. kel's uber pack is an example of this.But use this one if you want to replace notepad with notepad2 directly (next time u reformat). I havent used so i dont know how it works. http://www.ryanvm.net/forum/viewtopic.php?...otepad+replacer (Notepad2 2.0.18.3 (Modified) Folding/Replacement (code65536's release)
September 11, 200718 yr Author Thanks for the info, I found a way, I just copied over notepad.exe because I don't want to use thatc ya
