mastermark Posted September 10, 2006 Posted September 10, 2006 Hi peeps by the way great program wpi rulesjust a little problem i cant get the apps to install automatici put in a switch and nothing ieprog[pn]=['DVD It'];uid[pn]=['DVDIT'];dflt[pn]=['yes'];cat[pn]=['Applications'];forc[pn]=['no'];gcond[pn]=['FileExists(\'%programfiles%\')'];cmd1[pn]=['%wpipath%\\Install\\Sonic.DVDit!.v5.RETAIL-CROSS.30-7-04\\Setup\\setup.exe/VERYSILENT'];pn++;Im running it off the hardrive first just to play around with itWhat am i doing wrong ??????
VCC Posted September 10, 2006 Posted September 10, 2006 Actually, for a forced install I believe you want, forc[pn]=['no'];to be:forc[pn]=['yes']Also, your switch is to close to the executable.cmd1[pn]=['%wpipath%\\Install\\Sonic.DVDit!.v5.RETAIL-CROSS.30-7-04\\Setup\\setup.exe/VERYSILENT'];should be:cmd1[pn]=['%wpipath%\\Install\\Sonic.DVDit!.v5.RETAIL-CROSS.30-7-04\\Setup\\setup.exe /VERYSILENT'];Notice the space between setup.exe & /VERYSILENT otherwise you command is seen as setup.exe/VERYSILENT and the O.S. will not find that.
Avneet Posted September 11, 2006 Posted September 11, 2006 wrong place to ask this.. ak in the WPI forum
zorphnog Posted September 11, 2006 Posted September 11, 2006 The forc[pn] setting has nothing to do with your problem. Try adding the space as @VCC mentioned.
