if i try to open any Help file from within program i get the following error:
"there was a problem starting help"
if i try to manually start the .chm file by double-clicking it i get the following error
"Cannot open the file mk:@MSITStore:c:\program files\whatever the application is\nameofhelpfile.chm"
i have checked the registry entries (HKEY_CLASSES_ROOT\.chm key is "chm.file" and HKEY_CLASSES_ROOT\chm.file\shell\open\command is set to HH.exe)
i've made sure it's registered properly (regsvr32 hhctrl.ocx)
i have XP Home, SP2 and it used to work, but just not for a while
does any one any ideas?
thanks
Try the following commands:
regsvr32 /u "%windir%\system32\itss.dll”
regsvr32 /u "%windir%\system32\itircl.dll"
regsvr32 /u "%windir%\system32\hhctrl.ocx"
regsvr32 "%windir%\system32\itss.dll"
regsvr32 "%windir%\system32\itircl.dll"
regsvr32 "%windir%\system32\hhctrl.ocx"
After a reboot, try a .chm file again. If any of the above commands fail, you may have to do an sfc /scannow with the XP installation CD in the CD drive.
thanks for the replies
@cluberti
it seems the itss.dll and itircl.dll are missing from my system...
@TAIN
i tried the xCHM you suggested, and i can now, at least manually, open the .chm files. thank you. this will work until i get around to digging out my XP disk and trying to repair.
