right well heres the story. my pc isnt playing any sounds through the speakers when ever i try and play something it says No Audio Ouput Device is installed.
i know i need to install it, but i dont actually know what to install,
this is what is displayed in my device manager
pc info
HP m7360y series
Windows XP Media Center
Intel® Pentium® D dual core processor 820 (2.8GHz, 2MB,800MHz FSB)
Edited by neiantrim
Wrong forum, this is Software / Windows XP ;).
Install the sounddrivers, that´s all. Download the drivers from www.hp.com directly. I´m sure you will find the drivers for the modem too there if it came with the PC. Use the CD that came with your webcam to install the webcam.
Good Luck ;)
