PhoenixAF24 Posted January 17, 2006 Posted January 17, 2006 Ok... I am stumped....I have Win XP with all the latest patches and ensured that I don't have any spyware (I run a combination of S&D, AdAware, MS Anti-Spyware) and no virii (Up-to-date version of Norton 2006) and since last night I have the weirdest issue I have come across in 15+ yrs of computing... I cannot get the keystroke combination of Shift and M to work. Note I can hit Caps Lock and then hit m and I get M just fine. I cannot think of any program that would be monopolizing that keystroke.Any Ideas?P.S. Thinking hardware, have tried replacing keyboards... No go. When I use RDP, the problem exists on the remote client that I am connecting from so it's definitely a software issue Thanks,Brian
PhoenixAF24 Posted January 17, 2006 Author Posted January 17, 2006 Just wanted to add a twist to the problem. I just did a reverse RDP from the desktop to the laptop and when I am in the RDP session, shift m works fine within the RDP session but as soon as I minimize it, no longer works.
CptMurphy Posted January 17, 2006 Posted January 17, 2006 Have you installed any hardware recently? What you could do it, go to the desktop, start up the Windows Task Manager, click back on the desktop and hit that sequence and see if any programs start up. Or, alternatively, look at every process running and if any one seems odd. If it does, google it and see if it's either a normal process or something else.
PhoenixAF24 Posted January 17, 2006 Author Posted January 17, 2006 Answer #1 - No I haven't installed any new hardwareAnswer #2 - Just did a search for all processes and googled them all and all came up correct and valid.The next thing I am going to do is boot into safe mode and see if the prob occurs in safe mode. If that works then I guess msconfig is the next step and step by step adding processes until the problem occurs... ALLRIGHTY long night ahead for me B
PhoenixAF24 Posted January 17, 2006 Author Posted January 17, 2006 Hmmmm let me think about that .... Not yet... a little bit drastic but it's not too far from the top of my mind... I want to exhaust all other solutions first
CptMurphy Posted January 17, 2006 Posted January 17, 2006 Actually, XP lets you reinstall the OS without deleting your files. The only drawback is that you'd have these extra folders. Also, you'd have to make a new acc't because your old one was deleted. It's still there with all the files, but anyway...
eyeball Posted January 17, 2006 Posted January 17, 2006 u say it works via rdp so it must be working at some level. this might sound obvious but have you tried both shift keys? or just a different keyboard?thanks
PhoenixAF24 Posted January 18, 2006 Author Posted January 18, 2006 Wanted to let everyone know that the issue is fixed. Somehow in Skype, a hotkey had gotten assigned and enabled. Once I disabled that hotkey, issue disappeared !!! Thanks for everyone's suggestions. Thankful I didn't have to do a reinstall of Windows
kytran Posted July 30, 2010 Posted July 30, 2010 thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you
Tripredacus Posted July 30, 2010 Posted July 30, 2010 thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank you thank youEgads... Welcome to the MSFN Make sure to read our forum rules and try not to make posts like that one again.
