krick Posted March 2, 2005 Posted March 2, 2005 Can somebody tell me exactly what the service pack changes to solve the Win 9x 512M+ memory problem?Is the solution different on various flavors of windows?I'd like to have an installable patch that works on all 9x versions of windows that I can give out to my customers to fix this specific problem.Gape?
MCT Posted March 2, 2005 Posted March 2, 2005 http://www.3dspotlight.com/vb/showthread.php?s=&threadid=368
erpdude8 Posted March 11, 2005 Posted March 11, 2005 well hopefully the 512+ Mb memory fix will be included in the final release of Gape's W98se SP 2.0. in the meantime you should use the tips to limit the amount of RAM the Windows 'vcache' feature uses to 512 megs or less at the web site MCT mentioned.
