Yes there are. The PCI cards will always have a lower latency between the card and the bus. Also, if you buy a 802.11g USB adapter with a usb 1.1 interface or a usb 1.1 port, the speed will be limited to 11mbps (which is the speed of 802.11b). USB adapters should be avoided, as they do not provide the same connection quality/throughput as the PCI card version.
What about the USB 2 standard?
