brian873 Posted October 4, 2012 Posted October 4, 2012 Hi,I have a CMD file which extracts users from an Active Directory group then trims it so only the username is displayed in the output file GroupMemberTrim.txt.It works fine, however I would like to use dynamic file names instead of staticGroupMemberExtract.txt -> %groupname%-Extract.txtGroupMemberTrim.txt -> %groupname%-Trim.txtWhen I change this it breaks the FOR loop so the %%a variable does not read in the contents of %groupname%-Extract.txt instead it reads the filename %groupname%-Extract.txt as the %%a variable.Does anyone have any ideas how this could be fixed?Thanks @echo offCLS:GroupsMembersExtractecho.set /p groupname=enter groupname:echo.echo.dsquery * domainroot -filter "(&(objectClass=group)(name=""%groupname%""))" -l -d DomainName -attr member >>GroupMemberExtract.txt:GroupsMembersTrimCLSsetlocal enabledelayedexpansionFOR /F "tokens=1 delims=," %%a IN ( GroupMemberExtract.txt ) DO (set oldName=%%aset newName=!oldName:~3!echo !%newName!>>GroupMemberTrim.txt)SETLOCAL DISABLEEXTENSIONS:END
jaclaz Posted October 4, 2012 Posted October 4, 2012 Does anyone have any ideas how this could be fixed?Yes.http://homepage.ntlworld.com./jonathan.deboynepollard/FGA/questions-with-yes-or-no-answers.htmlI am not sure to have understood the issue (actually I am sure to have it not understood) Please post the .cmd that work and the one that doesn't and an example of the file to be parsed (GroupMemberExtract.txt).What is this?:!%newName!jaclaz
brian873 Posted October 4, 2012 Author Posted October 4, 2012 Hi Jaclaz, thanks for the replySorry !%newName! was a typo, it should be !newName!Ok here is the information you asked for.When the CMD file prompts for input at the line set /p groupname=enter groupname:I am entering AccountsWorking CMD file@echo offCLSecho.set /p groupname=enter groupname:echo.echo.dsquery * domainroot -filter "(&(objectClass=group)(name=""%groupname%""))" -l -d DomainName -attr member >>GroupMemberExtract.txtCLSsetlocal enabledelayedexpansionFOR /F "tokens=1 delims=," %%a IN ( GroupMemberExtract.txt ) DO (set oldName=%%aset newName=!oldName:~3!echo !newName!>>GroupMemberTrim.txt)SETLOCAL DISABLEEXTENSIONS:ENDGroupMemberExtract.txtCN=Joe Bloggs,OU=Accounts,OU=User Accounts,DC=DomainName,DC=company,DC=co,DC=ukGroupMemberTrim.txtJoe BloggsNon working CMD file with vairables@echo offCLSecho.set /p groupname=enter groupname:echo.echo.dsquery * domainroot -filter "(&(objectClass=group)(name=""%groupname%""))" -l -d DomainName -attr member >>"%groupname%Extract.txt"CLSsetlocal enabledelayedexpansionFOR /F "tokens=1 delims=," %%a IN ( "%groupname%Extract.txt" ) DO (set oldName=%%aset newName=!oldName:~3!echo !newName!>>"%groupname%Trim.txt")SETLOCAL DISABLEEXTENSIONS:ENDAccountsExtract.txtCN=Joe Bloggs,OU=Accounts,OU=User Accounts,DC=DomainName,DC=company,DC=co,DC=ukAccountsTrim.txtAccountsExtract.txtSo as you see, using the variables in this example throws out the %%a in the for loop and instead of phrasing the contents it uses the filename.
Yzöwl Posted October 4, 2012 Posted October 4, 2012 (edited) Before looking at the latter script I'd suggest you start by 'improving' the first one.Get rid of everything below the DSQUERY line and replace it with something like this:FOR /F "TOKENS=2 DELIMS==," %%# IN ( 'FINDSTR/B "CN=" GroupMemberExtract.txt') DO ECHO=%%#>>GroupMemberTrim.txt<EDIT />You will then see your problem which was caused by the inclusion of double quotes around the file name will have gone.FOR /F "TOKENS=2 DELIMS==," %%# IN ( 'FINDSTR/B "CN=" "GroupMemberExtract.txt"') DO ECHO=%%#>>GroupMemberTrim.txt Edited October 4, 2012 by Yzöwl see <EDIT />
jaclaz Posted October 4, 2012 Posted October 4, 2012 So as you see, using the variables in this example throws out the %%a in the for loop and instead of phrasing the contents it uses the filename.Yes/No.The contents of AccountsTrim.txt after the:set oldName=%%aset newName=!oldName:~3!should be:ountsExtract.txtBut as Yzöwl posted it is easier/better to change the actual code/method.If I get it right, you are using the for loop to "post process" the "integral" output of the dsquery command, you should be able to directly go to "GroupMemberTrim.txt" without having to pass through the "GroupMemberExtract.txt".There might be the need to add more than a efw ESCAPE characters but including the:dsquery * domainroot -filter "(&(objectClass=group)(name=""%groupname%""))" -l -d DomainName -attr memberinside a for loop seems to me like possible and "better".Let's say that (once having the special character being escaped properly) the above code is just "%Command%"FOR /F "tokens=2 delims=,=" %%A IN ('%Command%') DO ECHO %%Ait should work, see this as an example (working for me):@ECHO OFFSETLOCAL ENABLEEXTENSIONSECHO CN=Joe Bloggs,OU=Accounts,OU=User Accounts,DC=DomainName,DC=company,DC=co,DC=uk>test.txtTYPE test.txtFOR /F "tokens=2 delims=,=" %%A IN ('TYPE test.txt') DO ECHO %%ASET dsquery=CN=Joe Bloggs,OU=Accounts,OU=User Accounts,DC=DomainName,DC=company,DC=co,DC=uk>test.txtFOR /F "tokens=3 delims=,=" %%A IN ('SET dsquery') DO ECHO %%Ajaclaz
Yzöwl Posted October 4, 2012 Posted October 4, 2012 Just to prevent you getting confused with all of the suggestions for changing things, I'd just like to show you the difference betweeen your working and non working scripts.FOR /F "tokens=1 delims=," %%a IN ( GroupMemberExtract.txt ) DO (FOR /F "tokens=1 delims=," %%a IN ( "%groupname%Extract.txt" ) DO (The former is looking at a file whilst the latter is looking at a string.FOR /F ["options"] %%variable IN (file-set) DO command [command-parameters]FOR /F ["options"] %%variable IN ("string") DO command [command-parameters]This means that your non working script was parsing the string AccountsExtract.txt not the content of a file named AccountsExtract.txt.The result you should have seen as jaclaz pointed out above should have been ountsExtract.txt and not that which you posted and therefore potentially prevented others from solving your issue.
brian873 Posted October 4, 2012 Author Posted October 4, 2012 Thanks jaclaz & Yzöwl OK that makes sense now.I cant test it at the moment, will do it tomorrow. My only concern would be that %groupname% in some cases will contain spaces. I think omitting the " " will cause a problem. I will report what I find. FOR /F "tokens=1 delims=," %%a IN ( "%groupname%Extract.txt" ) DO (
allen2 Posted October 4, 2012 Posted October 4, 2012 I wouldn't do that task like this because:- the way you do it, if groups are members of the group you're trying to get members, you won't see the users members of those groups.- if the DN (you're parsing it in your script) doesn't contain the same "display name", you might end up getting wrong accounts. Usually i prefer extracting the samid or samaccountname (login for a user account) as they are unique and they can't contain space or special character.- for the same reason, i replaced a query on the samid of the group instead of its name.@echo offCLSecho.set /p groupname=enter groupname:dsquery group -samid %groupname% |dsget group -members -expand |dsget user -display >%groupname%Extract.txt Depend on your task, you might prefer using adfind as it is a lot more powerful and can format properly the output.
Yzöwl Posted October 4, 2012 Posted October 4, 2012 Thanks jaclaz & Yzöwl OK that makes sense now.I cant test it at the moment, will do it tomorrow. My only concern would be that %groupname% in some cases will contain spaces. I think omitting the " " will cause a problem. I will report what I find. FOR /F "tokens=1 delims=," %%a IN ( "%groupname%Extract.txt" ) DO (For such a scenario you could try:FOR /F "USEBACKQ TOKENS=2 DELIMS==," %%# IN ("%groupname%Extract.txt") DO ECHO=%%#>>"%groupname%Trim.txt"I would also suggest you use DSQUERY GROUP piping the results through DSGET as suggested above by allen2, it may seem a little OTT for you but it was the first approach I considered when I saw your initial post.
brian873 Posted October 5, 2012 Author Posted October 5, 2012 Thanks everyone I have it working the way I need it now.@allen2 - thats a fair point and a good one to look out for. However in this environment there are no nested groups and all usernames are generated from another system so should be fine with the current task.@Yzöwl - I have used the line you provided, thanks very much FOR /F "USEBACKQ TOKENS=2 DELIMS==," %%# IN ("%groupname%Extract.txt") DO ECHO=%%#>>"%groupname%Trim.txt"I will take a look at the other methods tools mentioned, but I can get what I need for now!Cheers
