Problem with Auto Logon : DefaultUserName does not change
I tried what was suggested in the Unattended Intermediate Guide, to create a user and allow auto logon.
The user is created. All three net command return : The command completed successfully.
But the DefaultUserName is not changed.
Any suggestions / corrections ?
Thanks.
net user "My_User_Name" "" /add
net localgroup Administrators "My_User_Name" /add
net accounts /maxpwage:unlimited
REGEDIT /S autologon.reg
EXIT
Windows Registry Editor Version 5.1
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DefaultUserName"="My_User_Name"
"DefaultPassword"=""
"AutoAdminLogon"="1"
Won't swear to this but I think if Fast User Switching is enabled then AutoLogon won't work.
Microsoft states that CTL+ALT+DEL must also be disabled.
I did not enable Fast User Switching.
Is it on by default ?
BTW, I used the above code after the unattended installation was complete.
Does that matter ?
Do I need to use cmdlines.txt ?
NB:
I did not use nLite.
I integrated XP SP3, and used a winnt.sif for the unattended install. The iso was created using CDImage.
Edited by ravisunny2
  • 1 month later...
If you don't want to keep your password in plain text in registry (may be accessed by everyone even via network in domain environment) look at LogonExpert autologon tool. It keeps your credentials AES 256bit encrypted.
It also supports the command line\script control
Thanks.
EXIT
Edited by hlanda
