fantasyz Posted October 18, 2009 Posted October 18, 2009 I have read the sticky post but still have some question on the wiring part.I am new to those TTL things. The RS232 to TTL I have here is a little bit different on the pins:T/R-T/R+RXD-RXD+GNDVCCthe sticky post have the following connection:- From PC (TX) to >>> RX (on Seagate)- From PC (RX) to >>> TX (on Seagate)- Connect GND and +5V to PC power supply, or similarso Q1. which pin should I use from the PC side to connect to RX/TX on Seagate HDD? My device have +/-.Q2. Should my CR2032 connect to the TTL device's GND and VCC? If the ans is yes, is the + side connect to VCC or the other side? (leaving the GND pin on HDD disconnected)Any help would be appreciated.
pointertovoid Posted October 20, 2009 Posted October 20, 2009 I didn't expect any relationship between a hard disk, an Rs232 (=serial port) link, nor a Cr2032 coin battery.In which kind of configuration or use do they meet?And by TTL, do you mean Transistor-Transistor-Logic?
TLH Posted October 21, 2009 Posted October 21, 2009 (edited) I'm no expert but I think Rx is 'data out' and Tx is 'data in' which would suggest you need a + and a - to make it work. You need to read through the sticky to find the correct wiring for what you have. There are a few pics with wiring there to look at. I went for the simple option and bought a dku-5 cable for £3 off fleabay, didn't need a battery and wiring is documented so it was easy to adapt. Edited October 21, 2009 by TLH
