October 1, 200916 yr I've been using WPI 7.1.1 for a long time with no problems on WinXP, if I upgrade to WPI 7.7, I have a problem were %CDROM% is not being defined.It may be caused by the way I have my folders structured, but I would prefer not to change it.I have included log files for both 7.1.1 and 7.7 versions.Thanks for any helpWPI_Log_7.1.1.txtWPI_Log_7.7.0.txt
October 3, 200916 yr WOW thats a hell of a project OK it looks like CDROM is not getting defined. (you are right) look at the variables section of your 2 logs.I will ask mritter to send you the .exe run file that we are instituting on monday when he gets home.For now though:How are you starting WPI? Edited October 3, 200916 yr by Kelsenellenelvian
October 3, 200916 yr Well heck I DO HAVE the last version!Please instead of running WPI.hta place this in the WPI folder and use it.Then tell me the result.
October 3, 200916 yr Author Thanks Kel, its my little home project I've been playing with to keep myself amused. WPI gets called from RunOnceEx.I 'm happy to continue to using 7.1.1 for now, but it would be nice to start using the latest versions. I have been aware of this since release 7.2 but have been lazy in chasing it up.EDIT: Thank Kel, i will give the EXE a shot and let you know Edited October 3, 200916 yr by 7yler
October 3, 200916 yr Author Just tested with WPI.EXE and the same problem, CDROM not Defined. Checking the log, both WPIPATH and ROOT get the correct drive, just not CDROM. %WPIPATH%=D:\APPS\Default.WPI\7.7.0 %ROOT%=D:\APPS\Default.WPI %CDROM%=Will continue to use 7.1.1 for now. Cheers7ylerWPI_Log_2009.10.03_22.32.22.txt
October 3, 200916 yr I am out of town so I will look at it Monday when I get all settled. Probably something simple I changed a while back that something else is affecting. Should be an easy fix.
October 7, 200916 yr Well, after getting home from trip, and next day my main computer crashed (drive in raid 0 fubar), I am on an old computer and back up to 80% speed.Here is the fix:core.jsline 104// Removable, ie, USB Keycddrv="";Delete the cddrv=""; line.Kel, get that updated in the main archive.
October 7, 200916 yr Author Nice one. Thanks Guys, it works great.I'm using WPI.EXE, and it works like a charm. Cheers.
