grafx1 Posted October 25, 2008 Posted October 25, 2008 What speed will i get if i receive poor or fair wireless signal ? the original ADSL speed is 1 M bit per sec. ?Thank you.
Kelsenellenelvian Posted October 25, 2008 Posted October 25, 2008 http://www.speedtest.net/ Why not try for yourself?
grafx1 Posted October 25, 2008 Author Posted October 25, 2008 http://www.speedtest.net/ Why not try for yourself?we didn't installed the router yet but i'm afraid that i may get low signal, so i'm asking how would poor signal strength affect speed...Thank you.
puntoMX Posted October 26, 2008 Posted October 26, 2008 The original ADSL speed is 1 M bit per sec. ?Wireless will do easily 1Mbps down and up, so if you go with the standard 54Mbps (N isn´t that much faster) you will have enough overhead to get the 1Mbps on a weak signal. Just remember to place your router/modem at a high spot...
grafx1 Posted October 26, 2008 Author Posted October 26, 2008 The original ADSL speed is 1 M bit per sec. ?Wireless will do easily 1Mbps down and up, so if you go with the standard 54Mbps (N isn´t that much faster) you will have enough overhead to get the 1Mbps on a weak signal. Just remember to place your router/modem at a high spot...Thanks puntoMX so much...and thanks Kelsenellenelvian for the link...
Kelsenellenelvian Posted October 26, 2008 Posted October 26, 2008 Hey no prob. I was assuming you already had the signal .
eyeball Posted October 26, 2008 Posted October 26, 2008 1Megabit per second at top speed would give you in theory 128kbps downstream, Consider you are on a signal that has a measurement of strength on a scale of 1-5, if you were getting the worst signal (i.e 1) you would in theory recieve 128/5 = 26kbps.I have not tested this theory but it makes sense to me that this is what you should expect
grafx1 Posted November 5, 2008 Author Posted November 5, 2008 1Megabit per second at top speed would give you in theory 128kbps downstream, Consider you are on a signal that has a measurement of strength on a scale of 1-5, if you were getting the worst signal (i.e 1) you would in theory recieve 128/5 = 26kbps.I have not tested this theory but it makes sense to me that this is what you should expect Thanks... i'll consider this
