Xp pro 64 bit slipstream problem
im trying to slipstream service pack 2, and it says its its not a valid win 32 application, i downloaded the srvice pack off the microsoft site
You need to slipstream the service pack for XP x64 within an x64 environment, such as XP x64, 2003 x64, or Vista x64.
Edited by 5eraph
Yes !!! you are trying in 32-bit environment...You must try to 64bit Windows
Have you tried slipstreaming SP2 from a CMD window?
WindowsServer2003.WindowsXP-KB914961-SP2-x64-ENU.exe /integrate:<sourcepath>
make sure you've got the right SP2, its the windows 2003 x64 sp2 you want
im using xp pro 64bit
It's corrupted! Sorry.
In fact, that error message usually means that the file is corrupted by far!
You likely only have a file that's not even 1 MB!
Please check you internet connection. The router or ethernet controller may be bad.
Edited by RJARRRPCGP
RJARRRPCGP,
Here is the information on SP2 from Kurt_Aust's post about integrating XP x64 stuff.
Service Pack 2 for Windows XP Professional x64 edition [367,964,016]
MD5: 46D05CE174437A224C8A77047D010AE9
SHA1: 7F8E909C52D23AC8B5DBFD73F1F12D3EE0FE794C
You might want to take a look at his thread.
Enjoy, John.
