Asus pc probe Fan and Voltage problem
Value is what they run at, and threshold is what they should run at. So in "Lamens terms" there running below standard to what the default settins are in PC Probe.
For example when i run Motherboard Monitor I have certian OC settings i run in my bios. Such as the Voltage supplied to my CPU thus makes MBM give me a alert. I turn it off. Just make sure your temps or ok.
That 40c....is that a INTEL? If so think about getting a better heatsink, way to hot if you ask me for a idle machine. I freak if mine gets over 29-30c on full load 35-36c
-XPerties
edited: I just saw your system specs...missed that. Im going to assume your using the default heatsink that came with the INTEL considering the RPM on the CPU fan are below 3000. I run mine at 7300-7400 rpm.
You need a new heatsink fan which will run fast, blow more air and cool that baby down. I personal love DELTA fans, but some say there to loud.
-XPerties
I can recommend Taisol heatsinks and fans.
http://www.taisol.com/coolers.html
If you get a heatsink that has thermal compound already stuck on wipe that cheap s*** off with an alcohol based cleaner,and replace with something like Arctic silver.
If you've got room in the case,a couple of 80mm case fans will also help with the cooling.One in the front pulling cold air in,and one in the back blowing out.
Sunon,Evercool or Delta do a good range of fans,Although as XPerties mentioned some people find the Delta's a bit loud.
actually from experiance alcohol based cleaner isnt good. Theres a product called "Go Gone" , use that. You can pick it up at any grocery store or house hold store. Make sure you buff the bottum of the heatsink for 10-15 min. Check artic silvers website for the instructions. Make sure you follow them closely.
-Xperties
[b:c1dcd687d5]Xperties[/b:c1dcd687d5]
This is a HP computerf so i dont exactly know what parts are in it, but when i opened it up, it looked like a pretty quality fan to me... Also i think there is something wrong with the readings or there is no sensor on my mobo cuz my comp was shut overnight and it was still at 40 C.. So im assuming all values shown there are not valid...
[b:c1dcd687d5]Reverend[/b:c1dcd687d5]
Thanks man, Ill look in to that :)
I don't have so much experience with taking out the fan and stuff but all others i can do easily.. the heatsink is somehow like stuck to the processor.. I tried to get it out and left it alone so i dont break it.. heh :rolleyes:
[b:c1dcd687d5]BAH[/b:c1dcd687d5]
Yeah, I tried MBM 5 .. It doesn't give me the correct readings either.. I think HP gave me a crappy Asus mobo that doesn't have the sensors built in.. this sux a** :cry
I just got the asus utility cuz i figured it would work cuz its an asus mobo.. but i guess not, If someone can recommend some other programs that may be able to read some stuff, i would appreciate it.. so far i have tried MBM, Hmonitor and Asus pc probe.. None have worked for me..
Thanks
BLACKWAR
Ive decided to use the warning/shutdown feature of my mobo and im trying to work out what temps I should set it for
[b:62be77cc21]BLACKWAR[/b:62be77cc21] - those fan speeds are truly pathetic, go get a good heatsink before u end up cooking something!!!
[b:62be77cc21]BAH[/b:62be77cc21] - checked out ur link to see what Max Die Temperature would be for my cpu's, so could config my mobo for warnings ( my XP 1800 run at about 95 degrees farenheit) and my ( P4 1.8 at about 89 degrees farenheit)
checked my board and cpu temps from cmos as well as sissoft sandra
now the AMD site says that the max die temps for the XP cpu is 190 degrees farenheit and the P4 at about 160
so what is the best temp to set warnings at, I was going to set mine from about 120f
[b:4d9494a58c]BLACKWAR[/b:4d9494a58c] - those fan speeds are truly pathetic, go get a good heatsink before u end up cooking something!!!
[b:4d9494a58c]BAH[/b:4d9494a58c] - checked out ur link to see what Max Die Temperature would be for my cpu's, so could config my mobo for warnings ( my XP 1800 run at about 95 degrees farenheit) and my ( P4 1.8 at about 89 degrees farenheit)
so what is the best temp to set warnings at, I was going to set mine from about 120f [/quote:4d9494a58c]
dood i dont think those readings are correct, ive seen the fan turn while my comp was on and it is impossible it is going at 1700 something.. I tell ya, my mobo doesnt have those sensor s***s...
So not to worry. :)
Thanks,
BLACKWAR
So not to worry. :)
Thanks,
BLACKWAR [/quote:24cc16994d]
lol...dont take me the wrong way but your fans will always be turning and yes it is possible for the fan to be running at 1700rpm, actually the basic fans run at that speed and up to 3200rpm. Unless you get a better quilty fan then those are the right speeds. And i havent a clue what sensors your refering to but your motherboard is no difference from any other motherboard, it does track the speed of your fans. Basically its a store bought computer and there all made to run at low standards thus making it quite. It does the job but the ASUS prob program your using is set on defaults to have the threshold of the boarderline cooling temps, voltage, and fan speeds.
-XPerties
-XPerties [/quote:706795cea6]
The thing i meant is thatmy mobo doesnt have all that sensing s*** on it so it wont sense the temp / voltage and stuff.. the other computer i had has a sensor and says around 5000 something rpm.. and there is no way the other computers fan is spinning faster than this one.. saw it with my own eyes man.. :)
well do this my friend....go into your bios and look for the temps and fan speed in there. write them down and let me know. I could be wrong but Im preety sure im not .........they have to have some kind of sensor that tells you so check your bios out
-XPerties
-XPerties [/quote:a65077e018]
i just looked in every place in the bios.. i didnt see anything...
Its something like the "Award Bios".. Its the crappy hp stuff so im guessing thats why they dont have temp s***...
BLACKWAR
