ysera Posted July 11, 2007 Posted July 11, 2007 (edited) after patching uxtheme.dll, i cant use right click on my startmenu... is there a way to re-enable it? can i use registry tweaks instead to enable my mouse right click? Edited July 11, 2007 by ysera
nuhi Posted July 11, 2007 Posted July 11, 2007 Patching uxtheme within nlite won't cause that. Never heard about it btw.
ysera Posted July 12, 2007 Author Posted July 12, 2007 is there a way i can reenabled it again?! i use nlite to remove some components and to patch the uxtheme and thats it!!
low_tech Posted July 12, 2007 Posted July 12, 2007 (edited) Maybe this....right clik start menu button \ properties \ customize \mark the "enable dragging and dropping" Edited July 12, 2007 by low_tech
nuhi Posted July 13, 2007 Posted July 13, 2007 low_tech, you're right. It's a tweak, perfectly normal.Somehow I missed the "start menu" part, probably was too hasty because of the impossible accusation about the patch.
ysera Posted July 13, 2007 Author Posted July 13, 2007 Maybe this....right clik start menu button \ properties \ customize \mark the "enable dragging and dropping"yay!!! thx low_tech!! solve the problem... thanks!!!
Maxfutur Posted July 14, 2007 Posted July 14, 2007 letme add something, dont reuse presets, is better to delete old presets, at least to me, sometimes, it disable extrathings without touching any...
nuhi Posted July 14, 2007 Posted July 14, 2007 Maxfutur, maybe you had to recheck all the pages after loading it, it can't do tweaks if that page is disabled for example.
