I'd have to say the first window flashes up and then disappears and then nothing. all the vbsript processes have ended.
I figure out the problem
It was this line, it works fine on Vista, but on XP it would not work.
 & Arg2.Path &
So I change it to this on XP and it works
 Chr(34) & Arg2.Path & Chr(34)
New Code
Save As ReportUpdates_V1.vbs
Dim Act :Set Act = CreateObject("Wscript.Shell")
Dim Fso :Set Fso = CreateObject("Scripting.FileSystemObject")
Dim Arg1, Arg2,Ts
Arg1 = Act.ExpandEnvironmentStrings("%UserProfile%\Desktop\UpdateReport.vbs")
Set Ts = Fso.CreateTextFile(Arg1)
Ts.WriteLine _
"Dim ColUpdates, ObjResult, ObjSession, Searcher" & vbCrLf &_
"Dim C1, C2, Confirm, Missing, V1, V2, V3" & vbCrLf &_
" V1 = Chr(160) & Chr(171) & Chr(160)" & vbCrLf &_
" V2 = Chr(160) & Chr(187) & Chr(160)" & vbCrLf &_
" V3 = V1 & ""---------------------------------------"" & V2" & vbCrLf &_
" WScript.Echo V3 & vbcrlf & V1 & ""Processing Search For Installed Updates""" &_
" & V2 & vbcrlf & V3" & vbCrLf & " WScript.Echo" & vbCrLf &_
"Set ObjSession = CreateObject(""Microsoft.Update.Session"")" & vbCrLf &_
"Set Searcher = ObjSession.CreateUpdateSearcher" & vbCrLf &_
"Set ObjResult = Searcher.Search(""Type='Software'"")" & vbCrLf &_
"Set ColUpdates = ObjResult.Updates" & vbCrLf &_
"'/-> Loop To Collect The Names" & vbCrLf &_
" For i = 0 to ColUpdates.Count - 1" & vbCrLf &_
" If ColUpdates.Item(i).IsInstalled <> 0 Then" & vbCrLf &_
" C1 = C1 + 1" & vbCrLf &_
" If Len(C1) = 3 Then C1 = C1" & vbCrLf &_
" If Len(C1) = 2 Then C1 = ""0"" & C1" & vbCrLf &_
" If Len(C1) = 1 Then C1 = ""00"" & C1" & vbCrLf &_
" Confirm = Confirm & V2 & C1 & V2 & ColUpdates.Item(i).Title & vbCrLf" & vbCrLf &_
" Else" & vbCrLf &_
" C2 = C2 + 1" & vbCrLf &_
" If Len(C2) = 3 Then C2 = C2" & vbCrLf &_
" If Len(C2) = 2 Then C2 = ""0"" & C2" & vbCrLf &_
" If Len(C2) = 1 Then C2 = ""00"" & C2" & vbCrLf &_
" Missing = Missing & V2 & C2 & V2 & ColUpdates.Item(i).Title & vbCrLf" & vbCrLf &_
" End If" & vbCrLf &_
" Next" & vbCrLf &_
" Dim Col1, Col2, Str1, Str2" & vbCrLf &_
" WScript.Echo V3 & vbCrLf & V1 & "" Confirm Installed Update "" & V2 & vbCrLf & V3" & vbCrLf &_
" Col1 = Split(Confirm,vbCrLf)" & vbCrLf &_
" For Each Str1 In Col1 :WScript.Echo Str1 :WScript.Sleep 250 :Next" & vbCrLf &_
" WScript.Echo V3 & vbCrLf & V1 & "" Missing Installed Update "" & V2 & vbCrLf & V3" & vbCrLf &_
" Col2 = Split(Missing,vbCrLf)" & vbCrLf &_
" For Each Str2 In Col2 :WScript.Echo Str2 :WScript.Sleep 250 :Next" & vbCrLf &_
" WScript.Echo V3" & vbCrLf &_
" WScript.Echo V1 & ""Processing Completed Search For Updates"" & V2 & vbcrlf & V3"
Ts.Close()
Set Arg2 = Fso.GetFile(Arg1)
Act.Run("%Comspec% /c @Echo Off &&" & _
"Color 9E && Title Update Report %ComputerName% " &_
"&& cscript.exe " & Chr(34) & Arg2.Path & Chr(34) & "&& pause"),1,True
Arg2.Delete()
Edited by gunsmokingman
yep that works. nice work.
Well at least on a real machine.
I get an error when I run it on VM:
C:\Documents and Settings\Administrator\Desktop\UpdateReport.vbs(10, 1) (null): 0x8024402C
But that might have something to do with the custom install I wazs testing on it. What all would this be relying on? Just the Update service?
I believe it relies on this object as to what services it needs to run I do not know.
With this object you can download and install the updates I believe.
Set ObjSession = CreateObject("Microsoft.Update.Session")
