steev Posted August 28, 2006 Posted August 28, 2006 If I'm writing in the wrong section - sorry!!Ok, this is my problem:I use Ryan to integrate the update pack and also a couple of addon packs. Then I use NLite to make a few changes and burn as an ISO file. then I use the virtual pc to test the tweaked XP Pro. After the copy has loaded I always get an error message in a box:The box is entitled"rundll32.exe - unable to locate component"The error message is: "the application failed to start because framedyn.dll was not found. Reinstalling the application may fix this problem".I've tried different addon packs and also different copies of XP pro but I always get this same error message. The only time it doesn't appear is when I burn an ISO with no update packs and no addon packs and no tweaks.Also, the message "new programme is installed" shows in the start menu but nothing is there, and I can't find any of the packs I integrate.what am I doing wrong?Many thanks for you help and adviceRegards steve
