zedox Posted August 16, 2006 Posted August 16, 2006 Afternoon all,What is the best order of installing media center, the hotfixs, rollups and .net versions?I hflsip all Windows XP Pro Updates.I nLite .net 1.1 sp1 with all updates, and .net 2.0 with all updates.During installation of Pro at T-13 stage, mce is installed.Is this the correct order?MCE appears to be installed, but If I go to execute it from the start menu it doesn't actually open.and any hotfixes or rollups do not appear on windows updates? Should they?Also... I get a registration message come up at the T13 stage, I know this is normal, but is there any way to surpress it, as i'm trying to go for the completely unattended way.cheers!
MagicAndre1981 Posted August 16, 2006 Posted August 16, 2006 just install Windows XP MCE. With RunOnceEx you have to install MS .NET Framwork 1.1 SP1, the UpdateRollup2 (extract the installer to get all seperate hotfixes and install them silently with "/passive /norestart"), Update KB912024 and the Juli Update RollUp.now you have a mce up to date
zedox Posted August 16, 2006 Author Posted August 16, 2006 In what order??What order...Currently...Windows XP PRoNet 1.1 sp1Net 2.0MCEand mce doesn't work...
MagicAndre1981 Posted August 16, 2006 Posted August 16, 2006 you also need .NET 1.0 SP3 because the Sonic DVD- and CD Burnng Tool needs this. And without the programm MC will not work.How do you install MC seperately?
zedox Posted August 17, 2006 Author Posted August 17, 2006 (edited) I've left net 1.0 sp3 in. As it's on XP Pro discs as default... isn't it?I'm using the wbpluto's thread to install mce at t12 stage from cmdlines.txtI just want to know, what order is best.and why no updates are showing up for me on windows updates. Edited August 17, 2006 by antonio_king
MagicAndre1981 Posted August 17, 2006 Posted August 17, 2006 aha, you don't have a real MCE, instead of this you want to make your Prof to a MCE.sorry, I have a genuine version of Windows XP MCE.
JuMz Posted August 17, 2006 Posted August 17, 2006 I've left net 1.0 sp3 in. As it's on XP Pro discs as default... isn't it?I answered your similar question in another thread. Yes, it is on the XP Pro CD in the CMPNENTS folder. HOWEVER, you need to have netfx=on in your unattend.txt for it to acutally install...it is NOT installed by default.
muiz Posted August 21, 2006 Posted August 21, 2006 There is already a tutorial on this oneuse the search button
zedox Posted August 21, 2006 Author Posted August 21, 2006 Give yourself a pat on the back MUIZ, you posted the most helpful pointless comment in this topic.
zedox Posted August 21, 2006 Author Posted August 21, 2006 (edited) What do I have to do to get media center updates to appear on windows updates?EDIT:Just realised have to do custom rather than express on windows update to get updates for media center. Edited August 21, 2006 by antonio_king
muiz Posted August 23, 2006 Posted August 23, 2006 (edited) http://www.msfn.org/board/index.php?showtopic=73305And yes i know the version numbers are out dated.I will redo the guide when i have time.But here is what you can do :Install MCE, best is with all normal updates in it , like with ryans pack etc.He doesnt include MCE hotfixes , so when you go to windows update the only hotfixes that are left are from MCE.Write them all down.The. put them like the guide, in your unattended@antonio_king , if i am pointless , what are you? Edited August 23, 2006 by muiz
