[Help] Wireless Network problem with Win XP
(Toshiba Satellite A40/45) Wireless: Atheros Ar5001X + Wireless Network Adapter.
Have a good day.
The problem is that the System failed so a workmate with another CD of win XP repaired the system (not reinstall just repair as he said) then the laptop stopped to detec the wireless network, someone told me that could be because of the driver of the Atheros but I don't even know whre can I find those drivers if that is the problem.
someone?
Title edited -- Please, use [TAGS] in your topic's title.
--Sonic
After 1min going to Toshiba website support ...
Link to the drivers (zip)
http://support.toshiba-tro.de/tools/Satellite/sa40/win-xph/wlesslan-sa40-xp-24214.zip
Uninstall previous version by Add/Remove program from Control Panel. Reboot.
Cancel the window of the wanted new drivers.
Install the downloaded drivers.
Check if you havn't disable Wireless Lan (wifi) with button on the notebook directly.
What exactly is the problem? Can you not see any wireless networks? or are you missing the option to view available wireless networks. If the latter, check to make sure that the Wireless Zero Configuration service is enabled.
