janus zeal Posted June 10, 2006 Posted June 10, 2006 I have installed windows vista on an Acer Aspire 5670, and every time the lcd powers down, it wont come back on. i know its not frozen because im accessing the internet through it to make this post with another computer.is there something i can do to make the lcd turn back on like its supposed to?
BoardBabe Posted June 12, 2006 Posted June 12, 2006 I have the same problem, Acer TravelMate 8600LMi, latest beta2. LCD will not power on. After eg. lid is closed.
janus zeal Posted June 13, 2006 Author Posted June 13, 2006 (edited) Ive yet to fix it, but it seems if you do Fn+F4 (might be diffrent for you) to put it into sleep then again to wake it will make the system resume. ^_^ Edited June 13, 2006 by janus zeal
BoardBabe Posted June 17, 2006 Posted June 17, 2006 Didn't work. Also shutting down frequently causes lcd to go dark and system freez.
BoardBabe Posted June 17, 2006 Posted June 17, 2006 I don't think the machine is responding, but as the LCD is shut off I have no way to find out
Biohead Posted August 30, 2006 Posted August 30, 2006 I had a similar problem when trying to standby. I would standby the machine, but rather than it go into SB mode (power LED flashes orange) the power button would remain blue but my screen would go off. I found that if I left it a few minutes, pressed the power button (to "resume" the laptop) it would then come back on as if it was brought out of standby.Im not sure, but I think the lack of being able to Standby is having "Away Mode" active so that my XB360 can always connect - its part of the Media Center setup.
xper Posted August 30, 2006 Posted August 30, 2006 My problem solved. HP ZT 3000 laptop with ATI Radeon Mobility. Get nevest driver for your video card and save it somewhere on HD.Connect external monitor. Start Laptop. LCD goes off but not external one. Computer --> Properties --> Update driver for video card. Hope this help someone.
