well my friend fourn a way to hack the deep freeze on my computer, its still there but i guess its just thawed or inactive, now there is a little blink red x on the little deepfreeze icon one the desk top toolbar, if that helps, but now i need to freeze it back up or unthaw it, ur help would be appreciated so much, im pretty computer illiterate
Just hold down the right Shift key and double click on the flashing icon in the tray. :thumbup
I cant because i dont know the password, my friend had to hack it to thaw it but thanx ne ways...does ne one know hoe to hack it?
You need to install the Deep Freeze Console and generate a One Time Password using the token at the password prompt screen.
If you don't have access to the Console, you can e-mail Faronics on this issue and you'll have to send them your license number for them to be able to generate a OTP.
Either that or your trying to circumvent a security protocol on a public computer perhaps?
YEah it is one a public computer i donno how this person hacked it to thaw it, but she said there was a way to unfreeze it without a password and hacking it, but she wont tell me because she is p***ed, and i need to hand this laptop back in, and its a 1000 dollar fine if it is thawed or whatever so im pretty much screwed i guess
