dasaint80 Posted April 5, 2006 Posted April 5, 2006 (edited) hey all, I trying to make my own boot screen and I'm having some problems. All the sites I go that have been posted here are not really helpfull for the building of actual image. I have photoshop, I got the layers and all built I just can't get the progress bar to work or the actual image to show at the actual bootup window.my image always ends up in the 900kb size, but I think that's slight too high.Thanks,steve Edited April 5, 2006 by dasaint80
Power350 Posted April 9, 2006 Posted April 9, 2006 (edited) Just make sure you have the pallet changed in the kernel file and one thing I did once was use infranview to convert image to bitmap after using photoshop. although you might see changes in the image after the conversion. Edited April 9, 2006 by Power350
machkris Posted December 24, 2006 Posted December 24, 2006 Can someone HELP me?I am trying to make my Boot Screen look like the one , but when Windows is booting up it is showing up as these LAST_SESSION.INI with distorted colors. Which file I need to edit in the Windows XP Pro CD and what do I need to do to correct this problem?
