hardwaregeek Posted April 3, 2006 Posted April 3, 2006 Hello everyone!I have a problem with usb pen drive after installing win xp sp2 with hotfixes with nlited. It is not the problem with nlite. But I use nlited cd with RVM update pack 2.0.4. Everytime normal user try to plug in usb drive, windows ask for administrator password. I did not have that problem before. I know it's something 2 do with permision. I set allow add or remove removable media, load and unload device driver settings in active directory.Still it requires admin credential. It is not a problem for one user. But it is the big problem for several user with different pen drive. Does anyone know how to allow anyone to use usb drive without requiring admin's credential? Thanks in advanced!!!!
yakkoxxi Posted August 14, 2006 Posted August 14, 2006 I have the same problem with nlite 1.0.1 finalEverytime that any user (except admin users) insert a usb flash drive, windows xp ask for admin user and passDid u resolve this issue????I start to tried fix it making some test with a normal windows xp install CD and a WinXP patch with nlite to check it
RyanVM Posted August 15, 2006 Posted August 15, 2006 1.) Use a newer update pack2.) Don't remove CAT files when integrating it
Guest csuser Posted September 8, 2006 Posted September 8, 2006 Is there a way to resolve this after the fact? It's affecting a few dozens PCs that I need to now fix.Thanks!
RyanVM Posted September 8, 2006 Posted September 8, 2006 You can try installing a hotfix which updates the USB drivers (such as KB918005). Otherwise, no. Live and learn.
