[HELP] Will the Logonui.exe form pro work on home?
Hi,
I have a modified logonui, on XP pro, and I would like to have it on my xp home machine too. is it possible to use the same file from pro, or do i have to redo the file with the logonui fro Home?
Thanks
HougTimo
Since Home and Pro are essentially the same OS, I'd say you at least have a good chance of it working properly in XP Home.
