March 17, 200620 yr I've searched MSFN for an answer to this strange problem in Win XP that occurred after I installed Frontpage 2003, but didn't find any useful info. In essence after installing FP, and rebooting the system, I can no longer load most of the Windows services in the Control Panel or many of the applications on my system. FP loads when I double click on an application or service, and in front of the FP splash I observe that the MS Installer is attempting to complete the FP installation. This action occurs for every loading of most of the applications on my system.When I log in as the Administrator there are no problems. I was able to uninstall FP via the Admin account. However, accessing the system via my standard user account produced multiple load errors during system initialization. I'm unable to perform a SysRestore or access the Registry via regedit due to the incipient FP load issues. Does anyone have some suggestions or references? I have a request in with MS Support, but it may take awhile for a response, and I need to get into my standard user interface to complete some critical work... Help!KenTitle Edited - Please follow new posting rules from now on.--Zxian Edited March 20, 200620 yr by Zxian
March 18, 200620 yr This should be in the office dissussion forum Please take some time to read the forum rules
March 20, 200620 yr @wolf74481 - His problem is with Windows, not Frontpage. The problem occured after installing frontpage, but deals with WinXP. Topic stays here.
March 20, 200620 yr I would try uninstalling FP then running a utility called MSICleanup. Do a web search to find the download. See if the problem still exists after doing this. I would also check the event viewer to see if any errors were reported there or if you can see any problems.
