[Help] Cmd Prompt Problem
Self explanitory problem, reset the computer several times, as well as virus/malware scans via nod32, spybot, ad-aware.
Last thing i wanna do is reformat so dont suggest that
Title edited -- Please, use [TAGS] in your topic's title.
Please follow XP Forum Rules from now on.
--Sonic
The full default path is
C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Try adding "SET path=" in front of that (no spaces around the equal sign!) and then see if you can run things. If so, you need to set the path to that in the System control panel.
