BlueMe Posted March 2, 2006 Posted March 2, 2006 (edited) I hope i got the right forum, so, does someone knows how can i connect my audio system to one of the cables from the power source. The Audio System stays On everyday no matter if my pc is up or not, so i would like it to power on only when i turn on my pc. On wich cable can i connect it to ? I need a 12V output. A.S. Spec: Medion 15 w RMS / 5+1 Chann.Thanks for reading. Edited March 3, 2006 by BlueMe
puntoMX Posted March 4, 2006 Posted March 4, 2006 Yellow and black will give you 12V. It’s just using 15W, like 1.25A, that’s not much. Only problem you could have it that you get a voltage ripple that returns to the PSU witch could damage other components on the same line... This is all that I can say about it. Some one else with more information?
BlueMe Posted March 4, 2006 Author Posted March 4, 2006 Thanks for the reply puntoMX, i thought about that thats why i've decided to start this thread. I guess i'll leave it that way if it is not another option.
