Masland Posted December 23, 2005 Posted December 23, 2005 I am looking for the registry tweak that allows for an expanded control panel using the classic start menu. The registry tweaks that I have found only work on the default xp start menu. Thanks.Also, is there any tool I can use to find this and other registry tweaks without having to post a question online? For example, I have tried using Regmon but I found that it was tough to decipher all the data it displayed...All responces are greatly appreciated, thx.Title Edited - Please follow new posting rules from now on.--Zxian
Kelsenellenelvian Posted December 23, 2005 Posted December 23, 2005 Windows Registry Editor Version 5.00[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]"ForceClassicControlPanel"=dword:00000001
prathapml Posted December 23, 2005 Posted December 23, 2005 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"CascadeControlPanel"="YES"Do try that out! You'd need to log-off & login for HKCU tweaks to take effect.Waiting to hear if it works or not....
Masland Posted December 23, 2005 Author Posted December 23, 2005 [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"CascadeControlPanel"="YES"Do try that out! You'd need to log-off & login for HKCU tweaks to take effect.Waiting to hear if it works or not....This worked, thank you! In fact, the following reg keys are available in that hive:[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]CascadeControlPanelCascadeNetworkConnectionsCascadePrintersCascadeMyDocumentsCascadeMyPictures
