Problem With XPSP1's "update.inf"
hi to all in the forum.
i have problem installing sp1...
after verifying and decompressing the files, a meesage pops saying:
"Setup could not verify the integrity of the update.inf. Make sure the Cryptographic servive is running on this computer."
I checked in "Services" and the above one is already running. i stoped and restarted it, but nothing. the message pops again.
i thought that it could be a bad download of sp1. so i tried one from a magazine's cd. the same.
i am logged of course as administrator. i am thinking of re-installing xp as my last option.
furthermore i dont think that it has anything to do with the "illegal key" issue.
could the problem be in the "update.inf" only? can anyone provide a link with just this file? any other suggestions?
vasilis
ok. i found the solution to the problem.
according to microsoft, the solution is to rename the folder "catroot2" in something else and then install the sp1a.
it worked!
vasilis
If I had been you, I would've made a slipstreamed CD with XP SP1a on it and done an update of XP without overwriting any of my programs, except for the files used by Windows... :)
