massiveoni Posted June 24, 2005 Posted June 24, 2005 (edited) hey all,i am very new to all of this, and i cant seem to find which switches will do silent installs on the following programs i have included the program name, and the file namenVidia Drivers - 71.89_win2kxp_english.exeAd-aware Personal - aawsepersonal.exeadobe reader 7.0 - adberdr70_enu_full.exeClone DVD 2 - SetupCloneDVD.exe (plus reg)DVD Shrink 3.2 - dvdshrink32.exeKazaa Lite Revolution 2.6 - kazaa.lite.revolution.2.6.english.exeMSN Messenger 7.0 - MSN Messenger 7.0.exe or MSN Messenger 7.0.msiMSG Plus 3.54 - MSGPlus-354.exeNERO Burning ROM 6.6.0.14 - nero-6.6.0.14.exewinace 2.5 - wace25.exe (plus reg)Winamp 5.09 - winamp5093_pro.exe (plus reg)Zone Alarm Suite - zaSuiteSetup_55_094_000.exe (plus reg)DVD Decrypter 3.5 - SetupDVDDecrypter_3.5.2.0.exeGetright 4.5 - getrt45d.exe (plus reg)can any one help me out, cause i am kinda lost,what i want it to do, is a silent install, installed in the default folder, and if it needs a reg, the for it to install that as well.atm i am trying to use Runonceex but not really getting anywerethanksjoel Edited June 24, 2005 by massiveoni
MAVERICKS CHOICE Posted June 24, 2005 Posted June 24, 2005 (edited) & WelcomeTry Here&This especially& I wouldn't recomend Runonceex to begin with. try batch files. Edited June 24, 2005 by MAVERICKS CHOICE
massiveoni Posted June 24, 2005 Author Posted June 24, 2005 hi,thanks for replying,yeh, i have been using the unattended.msfn.org but it is the apps installs i can get my head around it,when you say batch files,i know how to write basic batch files, but it was a fe years ago,can you help me out with some switches.do you have msn? if so, can you add me joelswatson@hotmail.comthanks
oioldman Posted June 24, 2005 Posted June 24, 2005 All yours apps have been discussed in great deatils in the Application Install area.Also, they are mentione don the unattended.msfn.org site, think in the intermediate section;http://unattended.msfn.org/intermediate/apps/intro.htmHope that helps.
massiveoni Posted June 24, 2005 Author Posted June 24, 2005 what would you recommend, batch filesor runonceex?or another programthe reason i want to use runonceex is cause it has the nice looking menu, and i dont like the look of the command prompt install
MAVERICKS CHOICE Posted June 24, 2005 Posted June 24, 2005 We don't have a problem helpin ya out, simply givin you a heap of script & throwin it together is not gunna help. For instance i have many different installers & repacked progs so my scripts for instance wouldn't help you.You really need to follow the guide & build from there, apparently there is a nice runonceex builder produced by a member that should help you along the way.I'm sure most of us here would like to see you have a go & if ya have trouble post ya script & describe what your doing & we'll go from there.Good luck & good readin...
Marthax Posted June 24, 2005 Posted June 24, 2005 Here it ishttp://www.msfn.org/board/index.php?showtopic=23751&st=0all credit goes to eagle00789 for creating this great program
