I have Blue Screen of Death all the time in my all systems which i have installed. One time it shows after 1 month, second 2 weeks, 1 week and then system doen't stars. Sometimes when i replace rams it work correct again for some time. WTF? HELP PLEASE ! :crazy:
A600 312Ram GeForce 64Mb MX400 Sound Blaster PCI Network Cart Windows XP SP1
Edited by Cezarek
try change your ram. also look on your mobo for capacitors if they are swollen. also install sp2.
Edited by boooggy
usually can be the ram. but also can be drivers that is kind of incompatible with xp.
so u can do a fresh install of xp slipstreamed with sp2 and last updates and then try the newest drivers for your hardware.
Is your hardware compatable with XP?
Is it a fresh install of XP or an image you intstalled from?
Have you checked the event log for information on the crashes?
Is it an overheating problem? - those Athlons are notorious for overheating - you need a beefy fan on there to keep it happy.
It really doesn't help.
Ehm, when i have that problem with BSoD and i reinstal windows then it's stil that fu***** screen. I must replace rams or graphic card to work porperly for some time again.
Fresh
I have hundreds of problems, crashes in log, because of that screen which appears many many times.
I had same problem when i install windows 98 when that hell begins, and on windows 98 system just restarts, like on XP, but without BSoD.
:o Is the RAM good quality or cheap stuff - cheap RAM can be like factory seconds/has low failure tolerance
And are all the errors different - or is there something common - if you share them maybe someone could help.
So have you got a heatsink/fan that's rated to cool a higher spec CPU than the A600 to give you some headway? Is the CPU seated correctly - flat and with heat transfer compound thoroughly applied?
Applications Log
2005-06-12 18:58:33 WinMgmt Ostrzeżenie Brak 62 Brak ZLOM Protokół WMI ADAP nie mógł przetworzyć biblioteki wydajności .NET CLR Networking, ponieważ jeden z obiektów danych typu blob zaraportował posiadanie klas, ale miał rozmiar zero.
2005-06-12 18:58:32 WinMgmt Ostrzeżenie Brak 62 Brak ZLOM Protokół WMI ADAP nie mógł przetworzyć biblioteki wydajności .NET CLR Data, ponieważ jeden z obiektów danych typu blob zaraportował posiadanie klas, ale miał rozmiar zero.
2005-06-12 18:57:47 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: Microsoft .NET Framework 1.1 -- Installation operation completed successfully.
2005-06-12 18:57:45 LoadPerf Informacje Brak 1000 Brak ZLOM Liczniki wydajności dla usługi .NETFramework (.NETFramework) zostały pomyślnie załadowane. Dane rekordu zawierają nowe wartości indeksu przypisane do tej usługi.
2005-06-12 18:57:40 LoadPerf Informacje Brak 1000 Brak ZLOM Liczniki wydajności dla usługi .NET CLR Networking (.NET CLR Networking) zostały pomyślnie załadowane. Dane rekordu zawierają nowe wartości indeksu przypisane do tej usługi.
2005-06-12 18:57:39 LoadPerf Informacje Brak 1000 Brak ZLOM Liczniki wydajności dla usługi .NET CLR Data (.NET CLR Data) zostały pomyślnie załadowane. Dane rekordu zawierają nowe wartości indeksu przypisane do tej usługi.
2005-06-12 18:55:58 ASP.NET 1.1.4322.0 Informacje Setup 1019 Brak ZLOM Finish registering ASP.NET (version 1.1.4322.0). Detailed registration logs can be found in C:\DOCUME~1\Mefhisto\USTAWI~1\Temp\ASPNETSetup.log
2005-06-12 18:55:58 ASP.NET 1.1.4322.0 Ostrzeżenie Setup 1020 Brak ZLOM Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS, please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i.
2005-06-12 18:55:58 LoadPerf Informacje Brak 1000 Brak ZLOM Liczniki wydajności dla usługi ASP.NET (ASP.NET) zostały pomyślnie załadowane. Dane rekordu zawierają nowe wartości indeksu przypisane do tej usługi.
2005-06-12 18:55:57 LoadPerf Informacje Brak 1000 Brak ZLOM Liczniki wydajności dla usługi ASP.NET_1.1.4322 (ASP.NET_1.1.4322) zostały pomyślnie załadowane. Dane rekordu zawierają nowe wartości indeksu przypisane do tej usługi.
2005-06-12 18:55:50 ASP.NET 1.1.4322.0 Informacje Setup 1017 Brak ZLOM Start registering ASP.NET (version 1.1.4322.0)
2005-06-12 18:55:45 MSDTC Informacje TM 4097 Brak ZLOM Uruchomiono usługę MS DTC z następującymi ustawieniami:
Konfiguracja zabezpieczeń (WYŁĄCZONE = 0 oraz WŁĄCZONE = 1):
Sieciowa administracja transakcji = 1,
Klienci sieci = 0,
Transakcje rozproszone używające wbudowanego protokołu usługi MSDTC = 1,
Transaction Internet Protocol (TIP) = 0,
Transakcje XA = 1
2005-06-12 18:46:04 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na C:
Typ systemu plików to FAT32.
Jeden z dysków wymaga sprawdzenia spójnosci danych. Mozesz
anulowac to sprawdzenie, ale zaleca sie jego kontynuowanie.
System Windows sprawdzi teraz dysk.
Numer seryjny woluminu: 80BF-CC91
Plik \System Volume Information\_restore{E9F975C8-F5A6-4698-B54D-443BEC382E26}\RP12\change.log.7 jest skrzyzowany w jednostce alokacji 1217430.
Skrzyzowanie skorygowano przez kopiowanie.
W folderze \System Volume Information\_restore{E9F975C8-F5A6-4698-B54D-443BEC382E26}\RP12 znaleziono wiecej niz jeden wpis change.log.
Zmieniono jego nazwe na change.lo0.
\WINXP\Tasks\SA.DAT pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\profile\opera.dir pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\profile\jswarn.dir pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\profile\urlwarn.dir pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\profile\global.dat pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Documents and Settings\Mefhisto\Dane aplikacji\Azureus\tracker.config pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Documents and Settings\Mefhisto\Dane aplikacji\Azureus\azureus.statistics pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
Czy przeksztalcac zagubione lancuchy na pliki (T/N)? Tak
3976 KB w 323 plikach odzyskanych.
System Windows wprowadzil poprawki do systemu plików.
5106676 KB calkowitego miejsca na dysku.
739120 KB w 552 plikach ukrytych.
8644 KB w 1847 folderach.
3118372 KB w 32631 plikach.
1240536 KB jest dostepnych.
4096 bajtów w kazdej jednostce alokacji.
1276669 ogólem jednostek alokacji na dysku.
310134 jednostek alokacji dostepnych na dysku.
2005-06-12 18:33:02 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na C:
2005-06-12 16:56:33 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na C:
Wpis \pagefile.sys zawiera nieprawidlowe lacze.
Wpis \pagefile.sys ma nieprawidlowy rozmiar.
Wpis \System Volume Information\_restore{E9F975C8-F5A6-4698-B54D-443BEC382E26}\RP12\A0013206.old ma nieprawidlowy rozmiar.
Wpis \Program Files\Opera\profile\vlink4.old ma nieprawidlowy rozmiar.
Wpis \Program Files\Opera\profile\cacheOp\dcache4.old ma nieprawidlowy rozmiar.
Plik \Games\Laxius Power ~ Random Story\Monster\Griphon.png jest skrzyzowany w jednostce alokacji 459734.
Plik \Games\Laxius Power ~ Random Story\Music\BattleEnd3.mid jest skrzyzowany w jednostce alokacji 458903.
Plik \Games\Laxius Power ~ Random Story\Sound\Numbness1.wav jest skrzyzowany w jednostce alokacji 458948.
\Games\Laxius Power ~ Random Story\123_LP_Instructions\LP\GASDER.BMP pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
Plik \Games\Laxius Power ~ Random Story\123_LP_Instructions\LP\LP_MAP.JPG jest skrzyzowany w jednostce alokacji 458937.
593708 KB w 33 plikach odzyskanych.
679944 KB w 545 plikach ukrytych.
8632 KB w 1847 folderach.
3093020 KB w 31804 plikach.
1325076 KB jest dostepnych.
331269 jednostek alokacji dostepnych na dysku.
2005-06-12 16:52:02 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0014ef7c.
2005-06-12 16:06:16 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd worldedit.exe, wersja 0.0.0.0, moduł powodujący błąd worldedit.exe, wersja 0.0.0.0, adres błędu 0x0006db20.
2005-06-12 15:05:15 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd gg.exe, wersja 6.0.0.130, moduł powodujący błąd archives.dll, wersja 1.0.0.1, adres błędu 0x0000912a.
2005-06-12 11:27:55 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0003a0cd.
2005-06-12 11:14:34 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x00000000.
2005-06-12 10:43:53 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0001d2c8.
2005-06-12 02:37:29 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x00818181.
2005-06-12 01:53:01 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-12 00:46:37 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0003a0cd.
2005-06-12 00:08:14 Windows Product Activation Ostrzeżenie Brak 1005 Brak ZLOM Ten produkt Windows nie został dotychczas aktywowany w firmie Microsoft. Użyj Kreatora aktywacji produktu w ciągu 21 dni.
2005-06-11 20:08:53 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd gimp-2.0.exe, wersja 0.0.0.0, moduł powodujący błąd gimp-2.0.exe, wersja 0.0.0.0, adres błędu 0x00072c0a.
2005-06-11 19:45:01 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd gg.exe, wersja 6.0.0.130, moduł powodujący błąd archives.dll, wersja 1.0.0.1, adres błędu 0x0000912a.
2005-06-11 19:44:17 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd gg.exe, wersja 6.0.0.130, moduł powodujący błąd archives.dll, wersja 1.0.0.1, adres błędu 0x0000912a.
2005-06-11 19:43:20 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd gg.exe, wersja 6.0.0.130, moduł powodujący błąd archives.dll, wersja 1.0.0.1, adres błędu 0x0000912a.
2005-06-11 19:23:45 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x010e42ca.
2005-06-11 18:56:11 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-11 17:33:35 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x00000400.
2005-06-11 15:51:38 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x025cc9f9.
2005-06-11 13:50:52 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x001dc5da.
2005-06-11 13:31:27 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: Alcohol 120% (Trial Version) -- Installation operation completed successfully.
2005-06-11 13:05:13 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na C:
671568 KB w 496 plikach ukrytych.
8068 KB w 1719 folderach.
2286664 KB w 28724 plikach.
2140372 KB jest dostepnych.
535093 jednostek alokacji dostepnych na dysku.
2005-06-10 16:44:50 Winlogon Informacje Brak 1002 Brak ZLOM Powłoka systemowa została nagle zatrzymana i uruchomiono Explorer.exe.
2005-06-10 16:16:39 Winlogon Informacje Brak 1002 Brak ZLOM Powłoka systemowa została nagle zatrzymana i uruchomiono Explorer.exe.
2005-06-10 16:16:36 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd explorer.exe, wersja 6.0.2800.1106, moduł powodujący błąd comctl32.dll, wersja 5.82.2800.1106, adres błędu 0x0002121c.
2005-06-10 16:04:28 MsiInstaller Informacje Brak 11728 Brak ZLOM Product: Mobile Phone Manager -- Konfiguracja zakończyła się pomyślnie.
2005-06-10 16:02:44 MsiInstaller Informacje Brak 11728 Brak ZLOM Product: Mobile Phone Manager -- Konfiguracja zakończyła się pomyślnie.
2005-06-10 16:02:09 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: Mobile Phone Manager -- Installation operation completed successfully.
2005-06-10 16:01:03 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: Mobile Phone Manager -- Installation operation completed successfully.
2005-06-10 16:00:46 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: ISScript -- Installation operation completed successfully.
2005-06-10 14:08:27 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na C:
System Windows sprawdzil system plików i nie znalazl zadnych problemów.
668048 KB w 477 plikach ukrytych.
7756 KB w 1648 folderach.
2098200 KB w 29426 plikach.
2332668 KB jest dostepnych.
583167 jednostek alokacji dostepnych na dysku.
2005-06-10 02:06:59 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x001f8913.
2005-06-10 01:19:00 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-10 01:00:21 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x00200076.
2005-06-09 21:55:06 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0001d2c8.
2005-06-09 09:26:19 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-09 09:25:46 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-09 09:16:03 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x000d5214.
2005-06-09 09:09:29 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Opera\Opera.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/09/2005 @ 09:09:29.673. Wygenerowany wyjątek to c0000005 pod adresem 67B4A0CD (Opera).
2005-06-09 09:09:27 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0003a0cd.
2005-06-09 00:42:00 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Microangelo\animator.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/09/2005 @ 00:42:00.793. Wygenerowany wyjątek to c0000005 pod adresem 0040CD91 (animator!DDAProc).
2005-06-09 00:41:58 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd animator.exe, wersja 0.0.0.0, moduł powodujący błąd animator.exe, wersja 0.0.0.0, adres błędu 0x0000cd91.
2005-06-08 23:20:57 Windows Product Activation Ostrzeżenie Brak 1005 Brak ZLOM Ten produkt Windows nie został dotychczas aktywowany w firmie Microsoft. Użyj Kreatora aktywacji produktu w ciągu 24 dni.
2005-06-08 18:40:49 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Opera\Opera.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/08/2005 @ 18:40:48.937. Wygenerowany wyjątek to c0000005 pod adresem 67B7F3A7 (Opera).
2005-06-08 18:40:45 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-08 08:53:21 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Opera\Opera.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/08/2005 @ 08:53:21.074. Wygenerowany wyjątek to c0000005 pod adresem 004D0020 (<nosymbols>).
2005-06-08 08:53:19 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x004d0020.
2005-06-08 08:47:20 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Opera\Opera.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/08/2005 @ 08:47:20.745. Wygenerowany wyjątek to c0000005 pod adresem 00000000 (<nosymbols>).
2005-06-08 08:47:18 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x00000000.
2005-06-08 08:39:53 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na D:
Numer seryjny woluminu: 09B9-A144
14420264 KB calkowitego miejsca na dysku.
3944 KB w 123 plikach ukrytych.
3776 KB w 440 folderach.
13297952 KB w 8613 plikach.
1114584 KB jest dostepnych.
8192 bajtów w kazdej jednostce alokacji.
1802533 ogólem jednostek alokacji na dysku.
139323 jednostek alokacji dostepnych na dysku.
2005-06-08 08:39:53 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na C:
\Recycled\Dc5.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc6.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc7.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc8.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc9.htm pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc10.js pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc11.htm pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc12.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc13.htm pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc14.htm pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc15.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc16.gif pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Recycled\Dc17.old pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\RivChat2\users\Mefhisto\rcsetup.cfg pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\RivChat2\users\Mefhisto\defskin.rcc pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\RivChat2\users\Mefhisto\Ignore.rci pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\Mail\ini3.tmp pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\Mail\ini66F.tmp pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Program Files\Opera\profile\cacheOp\dcache4.old pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Documents and Settings\Mefhisto\Dane aplikacji\Azureus\azureus.config.bad pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Documents and Settings\Mefhisto\Dane aplikacji\Azureus\downloads.config.bad pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
\Documents and Settings\Mefhisto\Dane aplikacji\Azureus\active\F99789DDA7BC65D90ADBBFBD94F6366E162A4304.dat.bak pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
Plik \Documents and Settings\Mefhisto\Ustawienia lokalne\Temporary Internet Files\Content.IE5\6DOF85QF\size[2].gif jest skrzyzowany w jednostce alokacji 723318.
\Documents and Settings\Mefhisto\Ustawienia lokalne\Temp\update.tmp pierwsza jednostka alokacji jest nieprawidlowa, wpis zostanie obciety.
344 KB w 26 plikach odzyskanych.
667912 KB w 442 plikach ukrytych.
7068 KB w 1540 folderach.
1978076 KB w 24737 plikach.
2453616 KB jest dostepnych.
613404 jednostek alokacji dostepnych na dysku.
2005-06-07 16:33:28 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Opera\Opera.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/07/2005 @ 16:33:28.821. Wygenerowany wyjątek to c0000005 pod adresem 67B7F3A7 (Opera).
2005-06-07 16:33:25 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd opera.dll, wersja 8.0.7561.0, adres błędu 0x0006f3a7.
2005-06-07 16:31:16 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja C:\Program Files\Opera\Opera.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/07/2005 @ 16:31:15.909. Wygenerowany wyjątek to c000001e pod adresem 0414D910 (<nosymbols>).
2005-06-07 16:31:13 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd opera.exe, wersja 8.0.7561.0, moduł powodujący błąd unknown, wersja 0.0.0.0, adres błędu 0x0414d910.
2005-06-05 23:42:39 Windows Product Activation Ostrzeżenie Brak 1005 Brak ZLOM Ten produkt Windows nie został dotychczas aktywowany w firmie Microsoft. Użyj Kreatora aktywacji produktu w ciągu 27 dni.
2005-06-04 16:52:03 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja D:\Gry\WARCRA~1\tools\w3chart.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/04/2005 @ 16:52:03.458. Wygenerowany wyjątek to c0000005 pod adresem 004044C5 (w3chart).
2005-06-04 16:52:02 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd w3chart.exe, wersja 1.0.0.1, moduł powodujący błąd w3chart.exe, wersja 1.0.0.1, adres błędu 0x000044c5.
2005-06-04 16:52:02 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja D:\Gry\WARCRA~1\tools\w3chart.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/04/2005 @ 16:52:02.176. Wygenerowany wyjątek to c0000005 pod adresem 004044C5 (w3chart).
2005-06-04 16:52:00 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd w3chart.exe, wersja 1.0.0.1, moduł powodujący błąd w3chart.exe, wersja 1.0.0.1, adres błędu 0x000044c5.
2005-06-03 00:38:20 DrWatson Informacje Brak 4097 Brak ZLOM Aplikacja D:\Gry\Warcraft III\tools\w3chart.exe wygenerowała błąd aplikacji. Błąd wystąpił na 06/03/2005 @ 00:38:20.853. Wygenerowany wyjątek to c0000005 pod adresem 004044C5 (w3chart).
2005-06-03 00:38:18 Application Error Błąd Brak 1000 Brak ZLOM Aplikacja powodująca błąd w3chart.exe, wersja 1.0.0.1, moduł powodujący błąd w3chart.exe, wersja 1.0.0.1, adres błędu 0x000044c5.
2005-06-03 00:25:55 LoadPerf Informacje Brak 1000 Brak ZLOM Liczniki wydajności dla usługi WmiApRpl (WmiApRpl) zostały pomyślnie załadowane. Dane rekordu zawierają nowe wartości indeksu przypisane do tej usługi.
2005-06-03 00:25:54 LoadPerf Informacje Brak 1001 Brak ZLOM Liczniki wydajności dla usługi WmiApRpl (WmiApRpl) zostały pomyślnie usunięte. Dane rekordu zawierają nowe wartości wpisów Last Counter (ostatni licznik) i Last Help (ostatnia Pomoc) do Rejestru systemowego.
2005-06-02 21:16:03 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: J2SE Runtime Environment 5.0 Update 1 -- Installation operation completed successfully.
2005-06-02 21:01:15 MsiInstaller Informacje Brak 11707 Brak ZLOM Product: WebFldrs XP -- Operacja instalacji zakończona pomyślnie.
2005-06-02 21:00:51 Windows Product Activation Ostrzeżenie Brak 1005 Brak ZLOM Ten produkt Windows nie został dotychczas aktywowany w firmie Microsoft. Użyj Kreatora aktywacji produktu w ciągu 30 dni.
2005-06-02 21:00:47 Winlogon Informacje Brak 1001 Brak ZLOM Sprawdzanie systemu plików na D:
3736 KB w 110 plikach ukrytych.
3728 KB w 434 folderach.
13546736 KB w 8425 plikach.
866056 KB jest dostepnych.
108257 jednostek alokacji dostepnych na dysku.
Fragment of System Log
2005-06-05 23:44:18 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 23:44:18 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 23:44:18 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-05 23:42:30 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-05 23:42:35 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-05 23:42:35 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-05 21:57:39 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-05 21:00:45 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: System Windows - Minimalna wartość pamięci wirtualnej jest za niska : System ma za mało pamięci wirtualnej. System Windows zwiększa rozmiar pliku stronicowania pamięci wirtualnej. W czasie trwania tego procesu, może wystąpić odmowa na żądania pamięci niektórych aplikacji. Więcej informacji możesz znaleźć w Pomocy.
2005-06-05 18:38:51 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Windows Image Acquisition (WIA) weszła w stan uruchomienia.
2005-06-05 18:38:51 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Windows Image Acquisition (WIA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 17:22:28 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-05 17:22:28 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-05 17:22:28 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 16:25:00 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-05 16:25:00 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-05 16:25:00 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 12:36:49 Windows File Protection Informacje Brak 64002 Brak ZLOM Podjęto próbę zamiany chronionego pliku systemowego c:\winxp\system32\msvcp50.dll. Dla zachowania stabilności systemu została przywrócona wersja oryginalna pliku. Wersja złego pliku: 5.0.0.7051.
2005-06-05 12:36:43 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Aktualizacje automatyczne weszła w stan zatrzymania.
2005-06-05 12:36:43 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa inteligentnego transferu w tle weszła w stan uruchomienia.
2005-06-05 12:36:43 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa inteligentnego transferu w tle został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 12:36:43 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Aktualizacje automatyczne został pomyślnie wysłany kod sterowania zatrzymaj.
2005-06-05 12:36:43 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Usługa raportowania błędów został pomyślnie wysłany kod sterowania zatrzymaj.
2005-06-05 12:36:42 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa raportowania błędów weszła w stan zatrzymania.
2005-06-05 11:20:00 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: VirtualDubMod.exe - Nie można znaleźć składnika : Uruchomienie tej aplikacji nie powiodło się, ponieważ nie znaleziono corona.dll. Ponowne zainstalowanie aplikacji może naprawić ten problem.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-05 11:11:25 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-05 11:09:37 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-05 11:09:42 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-05 11:09:42 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-04 23:17:33 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-04 22:49:41 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Windows Image Acquisition (WIA) weszła w stan uruchomienia.
2005-06-04 22:49:41 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Windows Image Acquisition (WIA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:24:17 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-04 21:20:39 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\ZBOCZONE-MISIE w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-04 21:15:50 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-04 21:15:50 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:15:50 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 21:13:17 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-04 21:11:24 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-04 21:11:29 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-04 21:11:29 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-04 19:39:51 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-04 17:33:14 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 17:30:29 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-04 17:29:38 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\ZBOCZONE-MISIE w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-04 17:28:33 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-04 17:28:38 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-04 17:28:38 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-04 16:54:37 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-04 16:51:39 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-04 16:51:39 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:51:38 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-04 16:51:38 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Telefonia został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 16:50:57 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-04 16:49:08 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-04 16:49:14 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-04 16:49:14 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-04 11:03:04 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-04 10:59:36 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\ZBOCZONE-MISIE w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-04 10:53:04 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-04 10:53:04 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 10:53:04 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-04 10:23:30 BROWSER Informacje Brak 8033 Brak ZLOM Sterownik przeglądarki wymusił wybór w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}, ponieważ przeglądarka główna została zatrzymana.
2005-06-04 09:47:41 Tcpip Informacje Brak 4201 Brak ZLOM System wykrył, że karta sieciowa \DEVICE\TCPIP_{3876D350-5EA5-4DE3-92FF-03412392FB50} została podłączona do sieci i ma zainicjowane normalne działanie na karcie sieciowej.
2005-06-04 09:28:02 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Windows Image Acquisition (WIA) weszła w stan uruchomienia.
2005-06-04 09:28:01 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Windows Image Acquisition (WIA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-04 09:06:16 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-04 09:05:35 Dhcp Ostrzeżenie Brak 1007 Brak ZLOM Komputer ma automatycznie skonfigurowany adres IP dla karty sieciowej o adresie 0050FCE4F6B3. Używanym adresem IP jest 169.254.0.249.
2005-06-04 09:04:25 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-04 09:04:30 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-04 09:04:30 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-03 19:41:20 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-03 14:05:12 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Windows Image Acquisition (WIA) weszła w stan uruchomienia.
2005-06-03 14:05:11 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Windows Image Acquisition (WIA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:05:04 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-03 14:01:36 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\HUNTER w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-03 14:01:15 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-03 14:01:15 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:01:12 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-03 14:01:12 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Telefonia został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 14:00:53 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-03 13:58:57 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-03 13:59:02 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-03 13:59:02 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-03 09:30:04 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-03 08:30:01 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-03 08:26:30 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\HUNTER w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 08:21:44 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-03 08:19:53 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-03 08:19:57 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-03 08:19:57 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-03 04:06:16 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-03 00:21:56 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-03 00:19:13 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-03 00:18:30 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\HUNTER w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-03 00:17:24 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: : Machine Check: Regs
2005-06-03 00:17:28 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-03 00:17:28 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-02 21:54:41 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-02 21:44:04 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-02 21:40:33 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\HUNTER w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa inteligentnego transferu w tle weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa inteligentnego transferu w tle został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:27:47 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługi terminalowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:26:04 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-02 21:26:04 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-02 21:25:21 EventLog Informacje Brak 6006 Brak ZLOM Zatrzymano usługę Dziennik zdarzeń.
2005-06-02 21:25:07 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Instalator Windows weszła w stan zatrzymania.
2005-06-02 21:05:18 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-02 21:05:18 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:05:18 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan uruchomienia.
2005-06-02 21:04:27 BROWSER Błąd Brak 8032 Brak ZLOM Usługa przeglądarki zbyt wiele razy nie zdołała pobrać listy kopii zapasowych w transporcie \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przeglądarka zapasowa jest zatrzymywana.
2005-06-02 21:02:46 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Telefonia weszła w stan zatrzymania.
2005-06-02 21:02:45 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi ElbyCDIO Driver został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan zatrzymania.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa COM nagrywania dysków CD IMAPI weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa COM nagrywania dysków CD IMAPI został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Instalator Windows weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Instalator Windows został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Zgodność szybkiego przełączania użytkowników weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZLOM\Mefhisto ZLOM Do usługi Zgodność szybkiego przełączania użytkowników został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługi terminalowe weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan zatrzymania.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Menedżer połączeń usługi Dostęp zdalny weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Menedżer połączeń usługi Dostęp zdalny został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Rozpoznawanie lokalizacji w sieci (NLA) weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Rozpoznawanie lokalizacji w sieci (NLA) został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Usługa odnajdywania SSDP weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Usługa odnajdywania SSDP został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7036 Brak ZLOM Usługa Połączenia sieciowe weszła w stan uruchomienia.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Połączenia sieciowe został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:01:40 Service Control Manager Informacje Brak 7035 ZARZĄDZANIE NT\SYSTEM ZLOM Do usługi Telefonia został pomyślnie wysłany kod sterowania uruchom.
2005-06-02 21:00:58 BROWSER Ostrzeżenie Brak 8021 Brak ZLOM Przeglądarka nie mogła pobrać listy serwerów z przeglądarki głównej \\HUNTER w sieci \Device\NetBT_Tcpip_{3876D350-5EA5-4DE3-92FF-03412392FB50}. Przedstawione dane to kod błędu.
2005-06-02 21:00:10 W32Time Informacje Brak 35 Brak ZLOM Usługa czasu synchronizuje teraz czas systemowy z czasem źródła czasu time.windows.com (ntp.m|0x1|192.168.100.9:123->207.46.130.100:123).
2005-06-02 21:01:15 SRService Informacje Brak 115 Brak ZLOM Monitorowanie Przywracania systemu zostało włączone na wszystkich dyskach.
2005-06-02 21:01:03 EventLog Informacje Brak 6005 Brak ZLOM Uruchomiono usługę Dziennik zdarzeń.
2005-06-02 21:01:03 EventLog Informacje Brak 6009 Brak ZLOM Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-02 20:59:39 Setup Informacje Brak 60054 Brak ZLOM Instalator pomyślnie zainstalował system Windows o numerze kompilacji 2600.
2005-06-02 20:53:14 Application Popup Informacje Brak 26 Brak ZLOM Podręczne okno aplikacji: System Windows - Brak dysku : W stacji nie ma dysku. Włóż dysk do stacji E:.
2005-06-02 20:53:14 Cdrom Ostrzeżenie Brak 51 Brak ZLOM Podczas operacji stronicowania wykryto błąd urządzenia \Device\CdRom0.
2005-06-02 20:48:44 Cdrom Ostrzeżenie Brak 51 Brak ZLOM Podczas operacji stronicowania wykryto błąd urządzenia \Device\CdRom0.
2005-06-02 20:42:28 EventLog Informacje Brak 6011 Brak ZLOM Nazwa NetBIOS i nazwa hosta DNS tego komputera uległy zmianie z MACHINENAME na ZLOM.
2005-06-02 21:35:35 Serial Informacje Brak 2 Brak MACHINENAME Podczas sprawdzania, czy \Device\Serial0 jest rzeczywiście portem szeregowym, wykryto kolejkę typu fifo. Zostanie ona użyta.
2005-06-02 21:35:49 EventLog Informacje Brak 6005 Brak MACHINENAME Uruchomiono usługę Dziennik zdarzeń.
2005-06-02 21:35:49 EventLog Informacje Brak 6009 Brak MACHINENAME Microsoft ® Windows ® 5.01. 2600 Dodatek Service Pack. 1 Uniprocessor Free.
2005-06-02 21:35:34 Serial Informacje Brak 2 Brak MACHINENAME Podczas sprawdzania, czy \Device\Serial1 jest rzeczywiście portem szeregowym, wykryto kolejkę typu fifo. Zostanie ona użyta.
> Is the RAM good quality or cheap stuff - cheap RAM can be like factory seconds/has low failure tolerance
I haven't that problem two maybe hthree years before. I have DIMS
> And are all the errors different - or is there something common - if you share them maybe someone could help.
Pasted
> So have you got a heatsink/fan that's rated to cool a higher spec CPU than the A600 to give you some headway? Is the CPU seated correctly - flat and with heat transfer compound thoroughly applied?
If you mean overcklocking then it's ok. I have reseted bios setings many times.
No Diff.
>Pasted
Oops - what language is that! :wacko:
No - I mean plain old overheating running at the preset clock.
Polish :)
Very low temperatureson CPU 25-33
