Help i have a problem starting Xplode
Hi ppl, i have a problem starting Xplode... I have installed Xplode in my $OEM$/$1/Install/Xplode Folder, but when i start it up nothing seems to happen so i started the run_with_logging.cmd, and here's the error it gives:
>>> Log session start at: 2005/04/19 07:11:37
XPlode4
  Adding environment variables
     #XPLODE# = 'E:\unattended\p origineel\$OEM$\$1\Install\Xplode'
     #SOURCEPATH# = 'H:\I386'
     #SOURCEDRIVE# = 'H:'
     #VERSION# = 'XPlode 4.00'
  XMLParser::LoadFile(E:\unattended\p origineel\$OEM$\$1\Install\Xplode\XPlode.xml)
     Error reading file: E:\unattended\p origineel\$OEM$\$1\Install\Xplode\XPlode.xml
>>> Log session end at: 2005/04/19 07:11:37
i dont have the XPlode.xml file, how do i get it? Do i have to write it myself or something?? Is there any guide besides the docs.pdf file?? i really dont understand much of it, and i'm a total newbie to this king of stuff. Can anyone please tell me how to get XPlode to work???
Thanx,
Gerben van Dijk
You need to write the xplode.xml yourself, using the manual, and the examples included in the package.
The board is also a good source for finding code snippets.
I'm a happy XPlode use for quite some time now,
so let me know if you need more help. Either here, mail or PM.
Preferred here so other can read it too.
okay, i found it out myself already, ive been editing one of the examples. im at the point of starting to add programs but im sure the manual says something about that. if i cant find out, ill ask you again. thanks!
