Doggie Posted November 5, 2002 Posted November 5, 2002 everytime i try and load a help file that involves spawning the xp help exe(c:\windows\hh.exe),it gives me an error all the time, force the program to shutdown.. i got the latest xp updates.. can someone help?thanx in advance
Crispy Posted November 5, 2002 Posted November 5, 2002 I get that one quite often too! Recently when i start Hitman 2 ... The only fix I have found is reinstalling windows ... (Not really a fix but ...)Properly not very helpful ...
Doggie Posted November 5, 2002 Author Posted November 5, 2002 i hope i don't need to reinstall again..
Reverend Posted November 5, 2002 Posted November 5, 2002 Run system file checker.Start > Run. Type in sfc /scannow Hit enter.(make sure you leave a space between sfc and / )
Reverend Posted November 5, 2002 Posted November 5, 2002 cheers Reverend.. fixed my problem No probs Doggie.
