I made a slipstreamed win xp pro with SP2 cd, which i am testing with virtual pc.
after loading all the necesary files, a few seconds after the GUI part of the setup starts, i get a message telling me that "battery" is not signed or something, and it asks me if i still want to install it (BATTERY.IN_ is what i found with the same name in the i386 folder).
its like the same mesage you get when you try to use a drivers that is not whql certified.
any ideas what could it be ?
aparently, windows works with or without it.
i used nlite to slipstream the SP2, and i took some things out, and applied some tweaks, but this battery thing started AFTER slipstreaminf the SP2, with no tweaks applied.
well i would assume that it installs drivers for batteries. if you are using a laptop, then you need the file, if not, then you don't need the file and you can ignore the error.
BUT....you know what happens when you a**-ume. :)
