dimegrind Posted July 23, 2004 Posted July 23, 2004 I am running WinXP Pro, which I just install a week ago.I played music for the first time and its all crackily.Its not the speakers tried them on another comp. I have a had pro on this machine before but I switch back to 2k where I had no sound probs, but now im back with xp pro and probs. The sound probs did occur when I had pro on the machine before. I am not sure what the prob is. I went to the site of my sound card and they do not offer a driver for XP. I went into decive manager and all is good. So what is the deal.My sc is a Montego II
MCT Posted July 23, 2004 Posted July 23, 2004 what type of files r u trying 2 play? consider updating Codecs ?
Phyridean Posted July 23, 2004 Posted July 23, 2004 Try this:go to control panel->sounds and audio devices->the upper "advanced" button->make sure under "options" that "advanced" is checked.Click on the advanced button below the volume control, and either check or uncheck "digital output only."Hope this helps,Phy
MCT Posted July 23, 2004 Posted July 23, 2004 also, i just thought of this, goto device manager & goto IDE ATA/ATAPI Controllersdouble click Primary IDE Controller , make sure transfer mode ISNT set to PIODo the same for any other's u have, secondary IDE controller..Last but not least, restart 4 changes 2 take effective heard that making stuff choppygood luck
neosapience Posted July 24, 2004 Posted July 24, 2004 It is possible to use Win2k drivers under XP. Try installing them and see if they work.
