sanjeeve Posted June 18, 2004 Posted June 18, 2004 I was wondering if water cooling would be quieter than air cooling...I am looking into getting a Koolance case, but I want to know if there is a better, quieter alternative!Thanks
Marsden Posted June 19, 2004 Posted June 19, 2004 It can be silent or even loud depending on the water pump and the fans blowing through the radiator.
sanjeeve Posted June 19, 2004 Author Posted June 19, 2004 well do you know how loud the Koolance cases are?
