XP PROBLEM (running cubase V)...
THANKS FOR YOUR PRECIOUS TIME. I HAVE A DELL PC RUNNING XP. BUT CAN'T USE MY CUBASE 5.1 SOFTWARE (COMPATIBILITY ISSUE). ANY HELP? - OR HOW CAN I HAVE MULTIPLE OS (+ MY XP TOO) ON A SINGLE DRIVE SO I CAN SWITCH TO WIN 2000 TO USE HARDWARE TO WORKING ON XP? URGENT! URGENT!! PLEASE.
Sorry Sagai, I noticed you had trouble finding the correct section to post your question in. I just found out that the software section in the Tech Support for XP Category was removed during the conversion from VBulletin to Invision Board. Its been restored now and your post has been moved :)
Oooo, so has this bloke forgot about us or still wants help?
Anyways, Cubase... If i remember correctly isnt Cubase a database program?
Dual boot is what its called. You need to make another partition to make your 2000 in and install to that. Partitions is not my strong point but im sure one of the other guys will help ya :) Partion Magic is the program you want i think.
