DaRKNeSS666NL Posted May 10, 2004 Posted May 10, 2004 I have looked and search this site and the kelly tweaks site but I can't find a reg tweak to set volume to max.Can It be done? Maby by making a regshot and setting it manualy to max and search for the chanches made???DaRKNeSS
Alanoll Posted May 10, 2004 Posted May 10, 2004 the regshot idea sounds like a plan, but I have a feeling you're going to run into some problems. You're most likely going to run into PnPIDs in the registry path.
DaRKNeSS666NL Posted May 10, 2004 Author Posted May 10, 2004 EEHHH PnPIDsI think Plug and play id's??If no one knows the answer I just going to give it a try. First I wil wait a wile. I am already glad that my idee is any good, and that for a noob like me. Thanks Alanoll for letting me feel a expert. DaRKNeSS
Alanoll Posted May 10, 2004 Posted May 10, 2004 lol. If you didn't say that, I would have said to do somethign similar And yeah, Plug and Play IDs.
jamesagmoore Posted May 11, 2004 Posted May 11, 2004 There's some APIs demo'd in the linkCodeprojectI also attach a basic implementation.
DaRKNeSS666NL Posted May 11, 2004 Author Posted May 11, 2004 Think I got it. I have launced reg shot and looked at the chanches made.Than Exporting them to a reg file. If I now set my volume to MIN after importing the reg file and rebooting the vol is set to MAX again.If sombody needs this reg tweak i have atached a file. (it's BETA)BEWARE I don't know jet if it wil work after a Unatended instal Going to try now or tomorrow.I Will make allso a note in the stiky tweaks threat if it works.DaRKNeSSMAX_volume_tweak.rarMAX_volume_tweak.rar
DaRKNeSS666NL Posted May 11, 2004 Author Posted May 11, 2004 YES It works (for me) don't know on a nother pc. But I have to take a look at the cd player, line in and pc beeb sound settings. They are still not set to max. But that doen't matter much to me< never use them any way.DaRKNeSS
DaRKNeSS666NL Posted May 12, 2004 Author Posted May 12, 2004 Can someone let me no if it works for you to. Iam curius if my first tweak is working fine.DaRKNeSS
